Bu Teardown'da Kullanılan Aletler
Giriş
Facts about floppy disks
- The casings are hard
- The disks are floppy
- Once opened, they don't go back together
- They're old.
The floppy disk has gone the way of the dinosaur.
Except for Google's lovable jumping dinosaur.
These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
It's worth noting that today's photos taken can be upwards of 10MB on their own!
Thin metal pieces are good places to start.
This one's so thin that you can bend it with a finger.
This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
With some careful prying, the entire lid pops right off.
You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
And we get a glimpse of what's inside! Spoiler alert: not much is there.
On the inside, we see a small pad, probably to clean the turning disk that's inside.
This one was pretty nasty. Eww.
This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
The meat n' bones of the floppy disk, the disk itself!
Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
This antique technology has virtually no replacement parts.
Replacement of the tape or cleaning pads are impossible without breaking the case.
The cleaning pads are held on with tight adhesive, making replacement difficult.
Attempts to use heat to loosen adhesive may result in the case melting.
High susceptibility to magnets make this device very sensitive.
10 Yorum
Super cool! Haven't seen a floppy disk in forever.
They are a tad old...haha
This is amazeballs. Solid work!
Great teardown! :)
Thanks! I tried...
I've found that floppy disks make great coasters! On a serious note, actually got a call from a client last week asking me if I could make a floppy disk for him, as his work computer didn't have a floppy drive. He emailed me the program. Turns out it was for some sort of CNC or milling machine that still uses floppies. Never count out the old school equipment.
Indeed! Neglect not.
1. You forgot the little plastic tab in the corner that blocks writing if necessary.
2. Repairability 1 out of 10: are you serious? you just never used Scotch tape to tape two halves of the body together. Also, that thing works happily without the metal shutter.
Come on man, everyone knows that scotch tape doesn't last more than a day. :)
