Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Franklin MWD-460A cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Franklin MWD-460A Teardown, Fully Assembled: adım 1, 2 resimden 1. Franklin MWD-460A Teardown, Fully Assembled: adım 1, 2 resimden 2.
    • Here is the fully assembled Franklin MWD-460A Electronic Dictionary.
  2. Franklin MWD-460A Teardown, Battery Compartment: adım 2, 3 resimden 1. Franklin MWD-460A Teardown, Battery Compartment: adım 2, 3 resimden 2. Franklin MWD-460A Teardown, Battery Compartment: adım 2, 3 resimden 3.
    • On the back of the case, locate the battery compartment, its cover, two grooves, and the tab (which locks the cover in place).
    • Release the cover by pulling down on the tab with a fingernail.
    • While holding the tab down, insert the opening tool into one of the grooves and gently pry the cover off.
  3. Franklin MWD-460A Teardown, Separating the Panels Part 1: adım 3, 3 resimden 1. Franklin MWD-460A Teardown, Separating the Panels Part 1: adım 3, 3 resimden 2. Franklin MWD-460A Teardown, Separating the Panels Part 1: adım 3, 3 resimden 3.
    • Locate the battery grooves.
    • Remove the batteries by inserting the prying tool into the grooves (sliding it underneath the batteries).
    • Locate the one screw inside the battery compartment, loosen it, and remove it.
  4. Franklin MWD-460A Teardown, Separating the Panels Part 2: adım 4, 3 resimden 1. Franklin MWD-460A Teardown, Separating the Panels Part 2: adım 4, 3 resimden 2. Franklin MWD-460A Teardown, Separating the Panels Part 2: adım 4, 3 resimden 3.
    • Locate the six tabs holding the two panels together along the sides.
    • Insert the prying tool into each of the six grooves and gently separate each tab from its insert on the other panel.
    • Finally, separate the panels from one another.
  5. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: adım 5, 3 resimden 1. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: adım 5, 3 resimden 2. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: adım 5, 3 resimden 3.
    • Locate the three screws holding the upper circuit board in place.
    • Loosen and remove the three screws.
    • The screw in the top right corner is also holding a tab in place so remember where it goes.
  6. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1 Continued: adım 6, 1 resimden 1.
    • Gently lift the upper circuit board to locate the up/down keypad and remove it.
    • Be careful when moving the upper circuit board as it's attached to the LCD screen and the lower circuit board.
  7. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 2: adım 7, 1 resimden 1.
    • Locate the eight screws holding the lower circuit board in place.
    • Gently pull up on the tape to expose the eighth screw.
    • Loosen and remove the eight screws along with their washers.
  8. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: adım 8, 2 resimden 1. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: adım 8, 2 resimden 2.
    • Gently lift the two circuit boards (along with the attached LCD screen) away from their case.
    • Now peel the lower keypad from its case.
  9. Franklin MWD-460A Teardown, Full View of Disassembly: adım 9, 1 resimden 1.
    • Here is a full view of the disassembled Franklin MWD-460A Electronic Dictionary.
Chris L
1.522 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
How can I fix the screen? The letters are so faded. :(
Paola Paniagua - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,157
