Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Game Boy Advance cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Game Boy Advance Teardown, Game Boy Advance Teardown: adım 1, 3 resimden 1. Game Boy Advance Teardown, Game Boy Advance Teardown: adım 1, 3 resimden 2. Game Boy Advance Teardown, Game Boy Advance Teardown: adım 1, 3 resimden 3.
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Game Boy Advance Teardown: adım 2, 1 resimden 1.
    • Remove the six back panel screws using a Y1 screw driver.
  3. Game Boy Advance Teardown: adım 3, 1 resimden 1.
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Game Boy Advance Teardown: adım 4, 1 resimden 1.
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Game Boy Advance Teardown: adım 5, 2 resimden 1. Game Boy Advance Teardown: adım 5, 2 resimden 2.
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Teardown: adım 6, 2 resimden 1. Game Boy Advance Teardown: adım 6, 2 resimden 2.
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Teardown: adım 7, 1 resimden 1.
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
  8. Game Boy Advance Teardown: adım 8, 2 resimden 1. Game Boy Advance Teardown: adım 8, 2 resimden 2.
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Game Boy Advance Teardown: adım 9, 3 resimden 1. Game Boy Advance Teardown: adım 9, 3 resimden 2. Game Boy Advance Teardown: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Game Boy Advance Teardown: adım 10, 3 resimden 1. Game Boy Advance Teardown: adım 10, 3 resimden 2. Game Boy Advance Teardown: adım 10, 3 resimden 3.
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  11. Game Boy Advance Teardown: adım 11, 3 resimden 1. Game Boy Advance Teardown: adım 11, 3 resimden 2. Game Boy Advance Teardown: adım 11, 3 resimden 3.
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  12. Game Boy Advance Teardown: adım 12, 1 resimden 1.
    • Use the tweezers to remove the black tape if needed.
Adam
851 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G29
5 Üyeler
62 adet Kılavuz yazıldı
7 Yorum
used this to replace the case and buttons on my GBA worked like a charm thanks!
Josh - Yanıt
I dont understand. The items in “Tools featured in this teardown" is different from the tools written on the article e.g. Y0 in “featured" but Y1 in the “article”.
darelldechavez - Yanıt
Bruh thx for
ColdPizza - Yanıt
Great guide. My dumb ass didn’t see the screws holding the circuit board to the front shell lmao
RikaSprout - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 39
Son 7 gün: 233
Son 30 gün: 791
Her zaman: 80,461
