Giriş
This year’s Pixel phones were leaked into oblivion, so when the keynote finally came, the internet gave a collective shrug. But you know what wasn’t leaked? The insides! And there’s only one way to get to get to those—with a teardown!
Want even more exciting teardown news? Check out our YouTube channel, follow us on Twitter, Instagram, or Facebook, and subscribe to our newsletter.
Neye ihtiyacın var
Videoya Genel Bakış
Normally we're all about high resolution, but this is shaping up to be the most Pixellated teardown ever. Check out the specs on our teardown unit:
6.3" OLED display with QHD+ 3040 x 1440 resolution (537 ppi) and variable refresh rate up to 90 Hz
Octa-core 64-bit Qualcomm Snapdragon 855 processor, paired with 6 GB of LPDDR4X RAM
Dual rear-facing camera with one 12.2 MP ƒ/1.7 wide-angle module, and one 16 MP ƒ/2.4 telephoto module; single 8 MP ƒ/2.0 wide-angle selfie cam
64 GB of onboard storage (128 GB optional)
IP68 ingress protection rating
Android 10 mobile OS
Lining up our new Oh So Orange Pixel 4 XL against last year's Clearly White 3 XL invites a few observations:
Notable changes include the loss of (one of) the front-facing speaker grilles and the fingerprint sensor of yesteryear. The new speaker setup still counts as stereo sound, but the lower speaker fires out the bottom (like an iPhone) instead of at your face.
The SIM tray also packed up and moved, likely to accommodate aforementioned speaker placement.
The Pixel 3's notch has evolved into a whole bezel! While everyone else in the industry works furiously to eliminate notches and bezels, Google's approach seems a little more laid-back.
At least they put the space to good use: inside they've crammed infrared facial recognition hardware, a wide-angle front-facing camera, and a cool new radar thing.
If this phone came with repair instructions, we're sure the first step would say "Apply heat to the surface marked in orange." So, we do just that.
The adhesive underneath is mercifully thin, but strong nonetheless. At this point, we'll take anything over that thick goopy gunk from last year.
With no more fingerprint sensor, we hoped to cut in without encountering any flex cable booby traps—but alas, a new even shorter cable connects the miscellany on the rear camera bump: flash, microphone, and the spectral + flicker sensor.
Fortunately, the wireless charging coil & NFC coil, newly adhered to the back panel via a sheet of adhesive, use repair-friendly spring contacts.
Bu adımda kullanılan alet:Manta Driver Kit - 112 Bit Driver Kit$69.95
We might not need all 112 bits to dismantle this Pixel, but we're glad we brought our Manta Driver Kit along for this one! We fish out a Torx 3 bit and start twirling away screws.
Normally, we love pulling out stretch-release adhesives—they're far more repair-friendly than messy tapes and glues. But you gotta pull at a shallow angle to avoid snagging and breaking them, and good luck doing that here. Like in the 3 XL, you'll likely need to remove the motherboard for adequate clearance, which requires many additional steps.
With the benefit of experience, we carefully complete the battery extraction using some IPA and gentle prying.
Underneath, a small but serious landmine lies in wait for would-be repairers: a delicate Active Edge flex cable, just begging to be accidentally sliced during battery extraction.
We have to dispose of quite a few brackets and shields on our way to the motherboard, but it's all worth it for these chips:
6 GB of Micron LPDDR4X RAM layered over the Qualcomm Snapdragon 855
SK hynix H28U72301CMR 64 GB Universal Flash Storage
Samsung K4U4E3S4AF-HGCJ mystery RAM, with a big "P" on it—best guess, this is dedicated RAM for the new Pixel Neural Core chip, likely hiding directly underneath
Pixel H1C2M3 Titan M security chip
Knowles 8508A quad-core audio processor, no doubt to help with the new live caption and transcription features.
Murata SS9709025
Avago AFEM-9106 (likely a front-end module)
If I were to make an educated guess, I would say that the mystery RAM is 4 Gb (0.5 GB) of LPDDR4x RAM :)
Side B of this record features:
Skyworks Sky5-8212-11 front-end module
Qualcomm QET5100 envelope tracker
Qualcomm PM8150 and PM8150A PMICs
STMicroelectronics ST54J NFC controller
Maxim MAX77826 companion PMIC
XSPT6 SMC85201 Z
Cirrus Logic CS35L36CWZ audio amplifier
ST54J is an NFC controller, with eSE/eUICC capability.
Thanks! We will update the chip ID with this.
Sorry! The module is actually more general-purpose than stated. I’ll adjust the text.
Chip ID, director's cut part 1:
Maxim Integrated MAX11261 6-ch. 24 bit delta-sigma ADC
Renesas (Formerly IDT) P9221-R 15 W wireless power receiver
Cirrus Logic CS40L25 haptic driver
Qualcomm PM8150S power management IC
Samsung S2MPG01 wireless charging chip (likely)
Dialog Semiconductor mixed signal array
Chip ID, director's cut part 2:
Qualcomm SDR8150 RF transceiver
Skyworks SKY78215-11 front end module
Skyworks SKY77365-11 quad-band GSM/GPRS/EDGE power amplifier module
Skyworks SKY13726-11 LMB/MB/HB/UHB diversity receive module
Skyworks SKY13727-11 MB/HB/UHB MIMO diversity receive module
Skyworks SKY53735-11 LB/LMB/MB/HB diversity receive module
Chip ID, director's cut part 3:
ON Semiconductor EMI8031MUTAG common mode filter w/ ESD protection
Texas Instruments TS3A5018 4-ch. SPDT analog switch
ON Semiconductor FSUSB242UCX USB-C analog switch
Bosch Sensortec BMP380 pressure sensor
STMicroelectronics LSM6DSR 3-axis accelerometer/gyroscope
STMicroelectronics LIS2MDL 3-axis magnetometer
The dual rear cameras come out, joined at the hip. They are nicely labeled "wide" and "tele" on the flex cables. Thanks, Google.
Next out: the front-facing sensors, including the 8 MP front-facing camera, and the
Face IDface unlock hardware. (The ambient light sensor stays stuck to the display for now.) -
The biometric hardware consists of two well-separated Near Infrared (NIR) cameras, a NIR flood emitter, and a NIR dot projector.
Next we pry out this hunk of ... stuff, which turns out to be an earpiece speaker, mic, ambient light sensor (AMS TMD3702VC), and the Soli chip, for interpreting your gestures using the power of radar.
Google calls this implementation of its in-house Project Soli Motion Sense.
Although radar technology has been in use for a long time and seems simple enough on paper, we're at a loss as to how Google stuffed the entire system into a tiny featureless rectangle with no moving parts.
The Soli chip then studies the reflected waves and analyzes their time delay, frequency shift, and other data to learn the characteristics of the object that reflected them—how big it is, how fast it's moving, in which direction, etc.
Soli then runs that data against its known gesture database to determine what action, if any, needs to be performed in the OS.
TL;DR: magic rectangle knows your every move.
If you want to learn more about the radar chip used, have a look here at the documentation of the actual manufacturer: https://www.infineon.com/cms/en/product/...
Here is another small package radar on a chip. Complete baseband, RF front end and antenna on a chip. https://www.digikey.com/product-detail/e...
Google gifted this Pixel with a supersmooth (sometimes) 90 Hz screen—a rarity thus far, even amongst the flagship-iest of smartphones.
Google also made sure nobody could take it from the Pixel without a struggle. Strong perimeter adhesive + screen layers going literally to the edge + giant duct-tape-like adhesive pad = screen does not want to come out intact.
In theory there's no reason to do this—only broken screens need be removed this way. But this is not a fun process for replacing an (all too common) broken screen.
On board, we also find a somewhat unexpected chip package from STMicroelectronics, likely a capacitive touchscreen controller.
GigaDevice GD25LH80C 8 Mb serial flash memory
Do you have the chip number for the ST one
It’s FJABH 07D924 83C0K. You can double check here.
Is the display optically bonded like the ones in iPhones?
Yes. The OLED panel is bonded to the glass. You won’t be able to replace the front glass only without specialty tools…especially because this is an OLED and not an LCD.
If anyone is here looking for tips on replacing the screen I just did my first P4XL.
The front glass glue is not as strong as I was expecting but they are not kidding when they say you won't be able to get it in one piece.
You can do this repair without removing the motherboard, but it does need to be loosened enough to move up a little to allow the board to move up. This basically means taking out the retaining screws and ribbon cables and nudging the board up over so slightly to slide the new connector in.
While its construction remains (disappointingly) familiar repair-wise, we did find quite a few treats in this pumpkin:
The Motion Sense-managing Soli chip lives next to the speaker at the top of the phone, and is incredibly tiny, considering its functionality.
Our best guess is that the Pixel Neural core is layered under some dedicated Samsung RAM, meaning it must be doing some heavy lifting.
We also found a new Knowles audio processor chip, which is likely a major player in all of the new on-device speech recognition features.
Samsung made the 90 Hz-capable display—looks like Pixel beat the Galaxy phones to the punch on this feature.
But back to that familiar feeling—what will this phone score?
What do you call that orange ribbon like mechanism in the middle? I accidentally ripped it when i changed the battery. I need to replace it tho. Thank you
- All screws are standard T3 Torx fasteners.
- The stretch-release adhesive securing the battery may not be foolproof, but its inclusion is repair-friendly.
- Waterproofing measures complicate repairs, but hopefully make them less common.
- Display repairs continue to be difficult, requiring complete disassembly of the phone.
- All repairs require access through the stubbornly-glued back panel.
- Glass on the front and back doubles potential drop damage.
Son Düşünceler
Onarılabilirlik Puanı
(10 en kolay onarılabileni)
40 Yorum
Any indication of why WiFi 6 is not supported despite being supported by the CPU? Is it missing a chipsets or antenna configuration that other WiFi 6 compatible phones have (that use the same Snapdragon 855 processor)?
The Murata WIFI chip in Step 5 does not support WIFI 6.
Ugly, not repairable, 2016-like specifications on a 2019 smartphone? Will NEVER buy for $1000
How does the FCC even allow this?
Lol - chill out buddy. And why would the FCC have anything to do with allowing a product to be released / priced / etc.? Unless you’re referring to the use of the Soli radar bands…
Matt J -
Remember all those phones from 2016 with 90 Hz refresh rates, radar, face unlock, e-sim.
So does the Pixel Neural Core chip, in fact, lie directly below the Samsung K4U4E3S4AF-HGCJ mystery RAM in a POP config?
If it is indeed the Neural Core, then yes! It would be a POP config.
Two and a half years after the pixel 1 release, you made a wallpaper of the guts… any chance we'll get the pixel 4 and pixel 4 xl guts wallpaper before 2021?
Can you say which GPS chip was installed?
You didn’t hit the “hyperspectral sensor” that’s glued to the top of the camera bump!
There’s been almost no detail revealed about that feature, save for passing keynote comments. Ya’ll still have a chance to update this teardown with a breaking analysis of what that might actually mean. (Nevertheless, solid post. Thanks!)
Here is a shot of the sensor. It is tiny (half the size of a grain of rice)! It looks like there is an imaging sensor covered by a grid of tuned filters. It’s able to detect specific frequency light through those filters.
While there are many uses for spectral imaging, Google introduced this tech in the Pixel 3 as a means to detect TV/monitor screen flicker so that when you record video, it can adjust to reduce flicker/banding. I think it’s still used for that purpose in the Pixel 4 XL.
Was going to consider upgrading to Pixel 4 from my Galaxy S5, but answer is a definite no. Lack of RAM. 6 GB is no better than my S5 from 5 years ago. Lack of a reasonable battery replacement. Incredibly small battery for 2019. Again, my S5 battery is larger, plus it can be replaced by me in 2 minutes. No headphone jack. No 4K / 60 frame video. Although I can live without this. No Wi-Fi 6. No 5G. Looks like I will be keeping my Galaxy S5 for another year or so. Sorry Google. You just don’t get it.
Dude your S5 is way way way wayyyyyy too old to even compare to a Pixel 2 XL, not to mention the Pixel 4 XL. I guess you haven’t tried the new gen phones. You should try them and think again.
Umm, the Galaxy S5 only has 2 GB of RAM and it’s a slower LPDDR3, with a battery that’s only 10.78 Wh (2800 mAH) (Samsung Galaxy S5 Teardown ). It’s time to upgrade! Toss the S5 to Verizon as $450 in trade-in towards the Pixel 4 XL and you’ll be a happy camper.
Trying to make sure my magnetic mount ring doesn’t obstruct the wireless charging coil.. how off center of the case is the coil’s center? Thanks
Here is a shot of the glass back. The intersection of the blue lines marks the back’s center, which is slightly above the charging coil’s center.
Thanks, that helps! I think I got it.
I realize a ruler laid along the length/height and width of the phone would be a helpful photo too. But this has been a big help.
I got a question! Isn’t it bad for the RAM to be layered over the SoC? I mean, all the heat the SoC produces will first spread to the RAM then it will be dissipated. It feels somewhat weird, altough it works (OEMs has been doing this as far as I can remember)
The radar almost certainly is not entirely contained in the pictured assembly. It shows a PCB antenna and some passive components - resistors, capacitors and inductors - but no active components, unless there is a die embedded in the PCB, which I doubt. There is probably an ASIC somewhere else in the phone that is energizing the PCB antenna and processing the received signals. I’d follow the flex traces back from the antenna and passives to see what active device is energizing them.
Check the comments on that step. There a multiple companies making single chip radar solutions.
Definitely not worth it for the price. I’d rather buy a 11 Pro for a higher price. Google isn’t made for making for phones, this isn’t their area of expertise. This is why I think that this phone isn’t such a huge tech bump, unlike the 11 Pro, which was a giant leap for iPhone. Other than the 90Hz screen at higher resolution and the extra RAM, it is nothing comparable to 11 Pro. I used to hold high expectations for the Pixel series, this phone disappointed me.
Yeah Google here with their neural core, audio processing and a bunch of other chips that no other manufacture have and yet it's still not worth it because on paper the specs doesn't look the best. You should try using it before you have a negative opinion.
could you remove the display without breaking it?
It is theoretically possible, but highly difficult due to the large amount of strong adhesives coupled with a fragile unreinforced OLED panel.
I have found a 4220mah battery for the xl, has anyone ever tried this upgrade?
do you know if there’s a DisplayPort over type-c chip on it?
Will this ram chip fit over the SoC and work.
MT53B512M32D2DS-062 AIT
My Pixel 1 (silver) was the most beautiful pixel ever produced. it was beautifully designed device in every aspect, internal and specially external,
somehow with every new pixel its getting more and more ugly. Not to mention bigger, for god sake bigger does not mean more customers ! please stop this non-sense of phones the size of my laptop!
Fellow phone technician here. i want everyone to know to not use a hotplate and very low heat to remove the back glass for repairs. the microphones and speaker circuits are very delicate to heat and static (found this out from an oem service provider after the screen repair). Im just not wanting my pricey mistake to repeat itself onto other technicians
can someone point out the GPS on this for me please?
Or if there are any antenna cables connected to it?
any idea ware is the display IC
Awesome breakdown and detailed information! I have a coral with a broken screen and came across you guys and after reading this I may attempt to replace the screen. I'll probably wait I believe screens are still pretty steep. Mine took a pretty hard hit right at the top just below speaker /reliever so petty sure digitizer and screen will need replacement. It also encountered the famous pixel 4xl “battery no charge " issue after it was dropped and screen broken so now it lives in a drawer.. yay! ;P
Appreciate you guys site and all the great information and detailed breakdown of various devices. ?
Edited
The antenna array assembly is not shown here (it should be that little long circuit right against the screen on the bottom part hold with two side screws. Apparently it’s one of the first things to go if any moisture get in from the lower part.
Any idea what ic chips are related to front camera and ir
