Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Bu Teardown'da Kullanılan Aletler
Giriş
In this guide you will learn how to teardown the HEC remote control
Bu teardown bir tamir kılavuzu değildir. HEC Remote Control cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Using a flat head screwdriver pry open the remote Using a flat head screwdriver pry open the remote
    • Using a flat head screwdriver pry open the remote
  2. Detach the circuit board from the bottom half of the remote casing. Be careful when removing the circuit board from the casing.
    • Detach the circuit board from the bottom half of the remote casing.
    • Be careful when removing the circuit board from the casing.
    • Springs are attached to the remote casing
  3. Remove plastic molding attached to the top half of the remote casing
    • Remove plastic molding attached to the top half of the remote casing
  4. Remove the lid encasing the batteries
    • Remove the lid encasing the batteries
Travis Go
158 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G15
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,905
