Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. HP Compaq 8200 Elite cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. HP Compaq 8200 Elite Teardown, Remove the cover: adım 1, 3 resimden 1. HP Compaq 8200 Elite Teardown, Remove the cover: adım 1, 3 resimden 2. HP Compaq 8200 Elite Teardown, Remove the cover: adım 1, 3 resimden 3.
    • There are no screws to remove, simply pull the handle on the cover towards you
    • It is recommended that you do this with the PC flat on the floor
  2. HP Compaq 8200 Elite Teardown, Remove the front cover: adım 2, 3 resimden 1. HP Compaq 8200 Elite Teardown, Remove the front cover: adım 2, 3 resimden 2. HP Compaq 8200 Elite Teardown, Remove the front cover: adım 2, 3 resimden 3.
    • There are 3 labelled tabs
    • Pull gently upward to release them
  3. HP Compaq 8200 Elite Teardown, Remove the CD-ROM: adım 3, 3 resimden 1. HP Compaq 8200 Elite Teardown, Remove the CD-ROM: adım 3, 3 resimden 2. HP Compaq 8200 Elite Teardown, Remove the CD-ROM: adım 3, 3 resimden 3.
    • Press down on the green button
    • Pull the drive backwards until you hear a small click, then raise it out of the caddy.
  4. HP Compaq 8200 Elite Teardown, Raise the drive caddy: adım 4, 2 resimden 1. HP Compaq 8200 Elite Teardown, Raise the drive caddy: adım 4, 2 resimden 2.
    • The drive caddy can be raised to allow access to the 3.5" drive bay below the CD-ROM
    • You don't have to remove the CD-ROM to do this.
    • This makes it easier to access the next 3.5" bay, too.
  5. HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: adım 5, 3 resimden 1. HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: adım 5, 3 resimden 2. HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: adım 5, 3 resimden 3.
    • The power supply is hinged, and swings away to reveal a 3.5" bay below.
    • As with the CD-ROM, press the green button to release the drive.
    • Pull back then up to remove.
    • Depending on your configuration, there may not be a drive in this bay.
  6. HP Compaq 8200 Elite Teardown, Access the PCI-E slots: adım 6, 3 resimden 1. HP Compaq 8200 Elite Teardown, Access the PCI-E slots: adım 6, 3 resimden 2. HP Compaq 8200 Elite Teardown, Access the PCI-E slots: adım 6, 3 resimden 3.
    • In the bottom-right corner, there is a tab
    • Lifting this up allows screw-free installation of PCI-E cards.
  7. HP Compaq 8200 Elite Teardown, Remove the fan shroud: adım 7, 3 resimden 1. HP Compaq 8200 Elite Teardown, Remove the fan shroud: adım 7, 3 resimden 2. HP Compaq 8200 Elite Teardown, Remove the fan shroud: adım 7, 3 resimden 3.
    • Make sure to unclip the cables routed through the shroud before removing it.
    • Only a very minor amount of force is required to remove the shroud.
    • This will allow you to replace the CPU heatsink or fan.
  8. HP Compaq 8200 Elite Teardown, Points of interest: adım 8, 3 resimden 1. HP Compaq 8200 Elite Teardown, Points of interest: adım 8, 3 resimden 2. HP Compaq 8200 Elite Teardown, Points of interest: adım 8, 3 resimden 3.
    • This workstation comes with spare Torx screws.
    • 5 Silver, 5 Black
    • Mine is missing one
    • These are also bitted for a flathead, but I had no luck actually unscrewing with one, so it's not recommended.
    • They are screwed into the chassis under the front cover
    • All screws in this device are Torx TR20. Ensure you have the correct bits before attempting board replacements
Darohan
283 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
I want this (pcb)motherboard please show amount
Manoj subhash narwade - Yanıt
i accadentally blew it up
Cosmo - Yanıt
thanks i needed this<3
Vega Star - Yanıt
I powered off correctly but next day computer failed to power on I tried to change power cable it didn't work no even the sign of light in motherboard. What will be the problem?
JAMES MWALUKO - Yanıt
I want to install new PSU, but the weird 4 pin connector doesn't look like anything on my thermaltake700 w (overkill, but just in its box here) can anyone help?
David Gagné - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 47
Son 30 gün: 203
Her zaman: 4,320
