Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. HP G61 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. HP G61-430SB Teardown, HP G61-430SB Teardown: adım 1, 1 resimden 1.
    • Turn the device over and remove the screws from the battery. Remove the black panels holding the HDD, ram, and wifi.
  2. HP G61-430SB Teardown: adım 2, 3 resimden 1. HP G61-430SB Teardown: adım 2, 3 resimden 2. HP G61-430SB Teardown: adım 2, 3 resimden 3.
    • Remove the RAM modules and the HDD as shown in the pictures.
  3. HP G61-430SB Teardown: adım 3, 2 resimden 1. HP G61-430SB Teardown: adım 3, 2 resimden 2.
    • Locate the screw for the DVD player and remove it. Then remove the DVD player with a thin spudger.
  4. HP G61-430SB Teardown: adım 4, 2 resimden 1. HP G61-430SB Teardown: adım 4, 2 resimden 2.
    • Remove the screws to remove the keyboard.
  5. HP G61-430SB Teardown: adım 5, 2 resimden 1. HP G61-430SB Teardown: adım 5, 2 resimden 2.
    • Remove the screws that are circled in the picture. These screws hold the case of the laptop.
  6. HP G61-430SB Teardown: adım 6, 1 resimden 1.
    • Remove the WIFI antenna cables from WIFI card.
    • Then remove the screws of the WIFI card and remove the card.
  7. HP G61-430SB Teardown: adım 7, 2 resimden 1. HP G61-430SB Teardown: adım 7, 2 resimden 2.
    • Flip the laptop around and gently remove the keyboard with your fingers.
    • Start with the corners of the keyboard.
    • Gently loosen the keyboard with a flat head screwdriver or a thin spudger.
  8. HP G61-430SB Teardown: adım 8, 2 resimden 1. HP G61-430SB Teardown: adım 8, 2 resimden 2.
    • After removing the keyboard, find the other screws located in the grey panel.
    • Remove the black plastic. Be careful with the white flat cable.
  9. HP G61-430SB Teardown: adım 9, 1 resimden 1.
    • Remove the black flat wire of the LCD screen from the motherboard.
  10. HP G61-430SB Teardown: adım 10, 1 resimden 1.
    • Remove the hinge screws with the screwdriver from the left side to the right side.
    • Under one of the two hinges, there is a hidden screw (case)
  11. HP G61-430SB Teardown: adım 11, 2 resimden 1. HP G61-430SB Teardown: adım 11, 2 resimden 2.
    • Remove the audio boxes.
    • Remove all the other wires and cables.
    • Then gently separate the screen from the case.
  12. HP G61-430SB Teardown: adım 12, 2 resimden 1. HP G61-430SB Teardown: adım 12, 2 resimden 2.
    • Use an iOpener to separate the grey case from the bottom case.
    • Careful: the battery compartment is together with the grey panel.
    • Tip: "slide" the iOpener while opening until you hear clicks. It is easy if you slide.
  13. HP G61-430SB Teardown: adım 13, 3 resimden 1. HP G61-430SB Teardown: adım 13, 3 resimden 2. HP G61-430SB Teardown: adım 13, 3 resimden 3.
    • Remove the motherboard by removing the screws first. Be careful with the cables and the wires.
    • Be careful with the connector of the DC power jack. You can replace the USB drivers on that side as well.
  14. HP G61-430SB Teardown: adım 14, 3 resimden 1. HP G61-430SB Teardown: adım 14, 3 resimden 2. HP G61-430SB Teardown: adım 14, 3 resimden 3.
    • Remove the cooler.
  15. HP G61-430SB Teardown: adım 15, 1 resimden 1.
    • To remove the Processor, unlock the processor socket with a flat screwdriver.
    • Then gently remove the Processor.
Kevin D
7.406 İtibar
21 adet Kılavuz yazıldı
2 Yorum
Thanks a bunch this helped a whole lot!!!!
Teresa halley - Yanıt
Thank you very much. Very well explained :)
a.thorne.987 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 9,126
