Ana içeriğe geç
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Neye ihtiyacın var
  1. Hamilton Beach "Keep Warm" Toaster 22811 Teardown, Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 1, 1 resimden 1.
    • Unplug toaster from wall.
    • Do not take apart a toaster that is plugged in.
    • If toaster has been used, lay down paper towels or work outside to avoid making a mess.
  2. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 2, 1 resimden 1.
    • Remove crumb tray from bottom of toaster.
  3. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 3, 1 resimden 1.
    • Remove these 7 screws from bottom of toaster.
  4. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 4, 1 resimden 1.
    • Remove bread lifter/toast booster by prying it off. The plastic piece snaps over the metal part during assembly. Use a flat-blade screw driver from the side to widen the gap in the plastic clip while pulling the plastic handle out. Done right the handle can later be reassembled securely.
  5. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 5, 1 resimden 1.
    • Disconnect the two circuits by unplugging the wires shown. This can be done by pressing the lever on the crimps. Then the shell can be pulled off from the rest of the toaster.
  6. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 6, 1 resimden 1.
    • Remove these 2 screws.
  7. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 7, 1 resimden 1.
    • Remove this screw.
  8. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 8, 2 resimden 1. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 8, 2 resimden 2.
    • Remove these 4 screws.
  9. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 9, 1 resimden 1.
    • Pull apart toaster components. If power cable needs to be removed or adjusted, unscrew the screws circled.
  10. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: adım 10, 1 resimden 1.
    • If the circuit for the buttons and shade selector needs to be removed, unscrew these 4 screws.
Alexander Yazdani
846 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G1
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 3,206
