Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Honeywell HF-910 Fan cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Honeywell HF-910 Fan Teardown, Removing fan cage: adım 1, 3 resimden 1. Honeywell HF-910 Fan Teardown, Removing fan cage: adım 1, 3 resimden 2. Honeywell HF-910 Fan Teardown, Removing fan cage: adım 1, 3 resimden 3.
    • First, locate 6 screws along the cage of the fan
    • Remove these 6 screws with phillips head screwdriver
    • Remove cage of fan
  2. Honeywell HF-910 Fan Teardown, Removing Fan Blade: adım 2, 2 resimden 1. Honeywell HF-910 Fan Teardown, Removing Fan Blade: adım 2, 2 resimden 2.
    • The fan should now look like the first picture
    • Locate the two phillips head screws behind the blades
    • Remove these screws
  3. Honeywell HF-910 Fan Teardown, Removing Motor: adım 3, 2 resimden 1. Honeywell HF-910 Fan Teardown, Removing Motor: adım 3, 2 resimden 2.
    • Remove the two screws that are circled in the photo
    • The motor becomes loose with only the wires holding it in place
  4. Honeywell HF-910 Fan Teardown, Accessing Speed Control Connection: adım 4, 2 resimden 1. Honeywell HF-910 Fan Teardown, Accessing Speed Control Connection: adım 4, 2 resimden 2.
    • Remove the screw that is circled in the first picture to access the speed control wires
    • The wires connecting to the speed controller are shown in picture #2
  5. Honeywell HF-910 Fan Teardown, Remove Power Supply: adım 5, 1 resimden 1.
    • Remove the circled screw in order to access the power supply
  6. Honeywell HF-910 Fan Teardown: adım 6, 1 resimden 1.
    • To reassemble device, follow these instructions in reverse order.
Jonathan Wood
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 49
Her zaman: 4,835
