Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Huawei P8 Lite cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Huawei P8 Lite Teardown, Huawei P8 Lite Teardown: adım 1, 2 resimden 1. Huawei P8 Lite Teardown, Huawei P8 Lite Teardown: adım 1, 2 resimden 2.
    • Remove the SIM & SD card trays first.
  2. Huawei P8 Lite Teardown: adım 2, 2 resimden 1. Huawei P8 Lite Teardown: adım 2, 2 resimden 2.
    • Remove the battery door—it's fastened tightly by clips. Free the clips with your fingernail or a pry tool.
    • Be careful because the midframe is easily scratched, and the glass at the top of the battery door is easily broken.
  3. Huawei P8 Lite Teardown: adım 3, 2 resimden 1. Huawei P8 Lite Teardown: adım 3, 2 resimden 2.
    • Remove the torx screws on the back.
  4. Huawei P8 Lite Teardown: adım 4, 2 resimden 1. Huawei P8 Lite Teardown: adım 4, 2 resimden 2.
    • Remove the loudspeaker by prying it up with a spudger.
  5. Huawei P8 Lite Teardown: adım 5, 3 resimden 1. Huawei P8 Lite Teardown: adım 5, 3 resimden 2. Huawei P8 Lite Teardown: adım 5, 3 resimden 3.
    • Remove the securing brackets covering the motherboard.
  6. Huawei P8 Lite Teardown: adım 6, 3 resimden 1. Huawei P8 Lite Teardown: adım 6, 3 resimden 2. Huawei P8 Lite Teardown: adım 6, 3 resimden 3.
    • Carefully release all the connectors on the board, and remove the motherboard.
  7. Huawei P8 Lite Teardown: adım 7, 3 resimden 1. Huawei P8 Lite Teardown: adım 7, 3 resimden 2. Huawei P8 Lite Teardown: adım 7, 3 resimden 3.
    • Remove the rear camera and front camera.
  8. Huawei P8 Lite Teardown: adım 8, 1 resimden 1.
    • Remove the power flex.
  9. Huawei P8 Lite Teardown: adım 9, 2 resimden 1. Huawei P8 Lite Teardown: adım 9, 2 resimden 2.
    • Remove the battery. There is strong adhesive under the battery—work carefully to pry it free and be careful not to puncture the battery.
    • Try an iOpener or hairdryer to heat the adhesive behind the battery. This softens the adhesive, making it easier to release the battery.
  10. Huawei P8 Lite Teardown: adım 10, 2 resimden 1. Huawei P8 Lite Teardown: adım 10, 2 resimden 2.
    • Remove the motor vibrator.
  11. Huawei P8 Lite Teardown: adım 11, 1 resimden 1.
    • Remove the sensor flex. It's covered under the digitizer flex and fastened by adhesive.
  12. Huawei P8 Lite Teardown: adım 12, 1 resimden 1.
    • Remove the earpiece speaker.
  13. Huawei P8 Lite Teardown: adım 13, 3 resimden 1. Huawei P8 Lite Teardown: adım 13, 3 resimden 2. Huawei P8 Lite Teardown: adım 13, 3 resimden 3.
    • Heat, cut the adhesive sticker and remove the screen carefully.
  14. Huawei P8 Lite Teardown: adım 14, 1 resimden 1.
    • You're done!
Sophia
43.810 İtibar
62 adet Kılavuz yazıldı
10 Yorum
Ciao ma la pistrina nera sulla batteria da dove posso comprarla? Perché mi è arrivato un terminale con il flat tagliato della pistrina e dovrei sostiturila.. Oppure può farne ammeno e cambio solo la batteria?
vito - Yanıt
thank you, its inspirating
buchta - Yanıt
Hello, I completed this repair and now the back-light is not working. Any suggestions? Know where I could locate a diagram of this board? TIA
beck74 - Yanıt
THis mobile audio ic for main speaker need information. because audio is full off on my phone but buzzer is health and good please help me but handset and small speaker are working
mohandes - Yanıt
Sir sent me p8 lite LCD light track
umarshazad001 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 60
Her zaman: 107,461
