Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Huawei Watch 3 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Huawei Watch 3 Teardown, Huawei Watch 3 Teardown: adım 1, 1 resimden 1.
    • Before we dive in, let's judge this book by its cover just a little:
    • 1.43 inch circular AMOLED touch display with 466 x 466 pixels (326 ppi) and a 60 Hz refresh rate
    • 2 GB RAM and 16 GB internal storage
    • Updated sensor array with newly included temperature sensor
    • 10 W wireless charging
    • 5 ATM water resistance (50 meters)
    • So far so good—let's dig deeper!
  2. Huawei Watch 3 Teardown: adım 2, 3 resimden 1. Huawei Watch 3 Teardown: adım 2, 3 resimden 2. Huawei Watch 3 Teardown: adım 2, 3 resimden 3.
    • Looking at this huge box, we'd expect the Huawei Watch 3 to be a little bit bigger—or at least to find a couple more watches.
    • This model goes by the the name GLL-AL04 and sports a digital crown and a side button.
    • Does the digital crown remind you of anything? We can't seem to place it.
    • On the rear we can already spot four screws securing the back cover (a good sign!) but the tiny notch behind the top band indicates a slightly more... complex opening procedure.
  3. Huawei Watch 3 Teardown: adım 3, 2 resimden 1. Huawei Watch 3 Teardown: adım 3, 2 resimden 2.
    • The Watch 3 has some stiff competition. From left to right: Huawei Watch 2, Huawei Watch 3, and the Galaxy Watch3.
    • We see an increased display size compared to its predecessor, courtesy of the smaller bezel.
    • Where the Galaxy Watch3 puts that bezel to work navigating menus and scrolling, the Huawei Watch 3 delegates those tasks to its digital crown.
    • On the back, we see Huawei doubled down on the optical sensors—and switched to wireless charging, as the contact pads of yesteryear are no more.
  4. Huawei Watch 3 Teardown: adım 4, 2 resimden 1. Huawei Watch 3 Teardown: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    Satın Al
    • With the four rear Torx screws out of the way we'd hoped to get in with just an opening tool, but this year's Huawei timepiece needs a little more force.
    • Some heat and a Jimmy finally crack our clam open to reveal adhesive instead of a repair-friendly rubber gasket keeping the watch watertight.
    • The proper tool for prying would probably be a watchmaker's knife. "Hey Celia, add a watchmaker's knife to my shopping list."
    • Strong adhesive paired with a flex cable butted up close to the cover's edge makes for a harrowing opening journey.
    • Moving that cable out of harm's way and opting for a reusable rubber gasket would simplify the procedure.
  5. Huawei Watch 3 Teardown: adım 5, 2 resimden 1. Huawei Watch 3 Teardown: adım 5, 2 resimden 2.
    • After popping the watch open, the Jimmy returns for some more heavy-duty prying.
    • Most of the components in the sensor assembly are held in place by Phillips screws or brackets, and a couple rivets. Riveting! Regardless of fastener, the components are stuck on non-removable flex cables, hampering repairs. Not to mention the sensor array itself which is heavily secured to the back cover.
    • All our hard work yields only one replaceable part on the back cover—the loudspeaker. At least we got something.
    • While optical heart rate and blood oxygen sensors are common in smartwatches, a temperature sensor is rather new. Maybe it's not the worst to check your body temperature once in a while, especially in this day and age.
  6. Huawei Watch 3 Teardown: adım 6, 3 resimden 1. Huawei Watch 3 Teardown: adım 6, 3 resimden 2. Huawei Watch 3 Teardown: adım 6, 3 resimden 3.
    • With one more small bracket out of the way we have full access to the battery. A little spudgering here, a little sputtering there, and the battery's free from its adhesive.
    • This powerhouse is rated at 1.78 Wh (460 mAh @ 3.87 V) and is supposed to offer you 3 days of fun with your smartwatch—or up to 14 in "ultra-long battery life mode!"
    • For comparison, the Xiaomi Mi Watch (2021) battery packs 1.62 Wh but allegedly lasting 16 days—either an efficiency or marketing difference there. The Galaxy Watch3 comes with 1.3 Wh, and the Apple Watch Series 6 with 1.17 Wh.
    • The battery, like many others, uses a classic soft-shell design. It makes us wonder why Apple seems to be the only manufacturer experimenting with metal pouch batteries.
  7. Huawei Watch 3 Teardown: adım 7, 2 resimden 1. Huawei Watch 3 Teardown: adım 7, 2 resimden 2.
    • The motherboard finally grants us a break from prying—a Phillips driver is all we need to free this board.
    • Motherboard out of the way, we turn to the 1.43-inch AMOLED screen and it's back to adhesive. That display is firmly adhered.
    • And is it just us, or is that ambient light sensor waving at us... mockingly?
    • Since this watch is already in its third generation with a variety of offshoots, we'd hope for a more repair-friendly solution by now. Maybe Huawei could take a page from Samsung's Galaxy Watch book?
  8. Huawei Watch 3 Teardown: adım 8, 3 resimden 1. Huawei Watch 3 Teardown: adım 8, 3 resimden 2. Huawei Watch 3 Teardown: adım 8, 3 resimden 3.
    • With the motherboard out, we find the bottom of it rather… unspectacular at first sight. A big battery recess and all of the cable connectors set up camp here, but deeper down we spot some hidden chips:
    • CMJRD11G04G 16 GB NAND flash storage (likely) layered above maybe a WiFi processor
    • Ambiq Micro AMAP42 Apollo4 SoC
    • Runic RS7222 USB 2.0 DPDT analog switch (likely)
    • We're not in the mood to camp here with them for long, so we hurry over to more important sightseeing. Onward!
  9. Huawei Watch 3 Teardown: adım 9, 3 resimden 1. Huawei Watch 3 Teardown: adım 9, 3 resimden 2. Huawei Watch 3 Teardown: adım 9, 3 resimden 3.
    • The top of the motherboard offers the following important-looking silicon:
    • GF2EE1-16G-X 2 GB SDRAM (likely) with a HiSilicon Hi6262 Kirin 710 layered underneath
    • HiSilicon Hi6556 GFCV100 Power IC
    • HiSilicon Hi6D05 Power Amplifier Module
    • Airoha AG3335SD RFSoC GPS receiver
    • HiSilicon Hi1132—which is basically the Kirin A1 (running an ARM Cortex-M7 SoC) w/ Bluetooth controller
    • Texas Instruments BQ25601 Single Cell Battery Charger
    • HiSilicon Hi6353 RF transceiver (likely)
  10. Huawei Watch 3 Teardown: adım 10, 1 resimden 1.
    • Smaller (and still important!) bits and pieces:
    • STMicroelectronics 54HJJ9 NFC controller
    • HiSilicon 6H03S LNA/RF switch (likely)
    • 85G1 AAAC, likely an antenna switch module
    • HiSilicon 656211 power management IC
    • Cirrus Logic 35L36A audio amplifier
    • X-Powers AC107 2-channel audio capture A/D converter
    • Omnivision Group (formerly Will Semiconductor) WAS4646C 2:1 SPDT analog switch
  11. Huawei Watch 3 Teardown: adım 11, 1 resimden 1.
    • With that, the Huawei Watch 3's time with us is over. All these glued and connected parts means we're left with a lot of big pieces, but at least the battery—which is guaranteed to eventually fail—is out of the watch.
    • Unfortunately we don't see that much evolution repair-wise from this series. Quite the opposite: more components crammed in and fewer that are independently replaceable.
    • Let's go ahead and see what all that means for scoring!
  12. Son Düşünceler
    • Only press fit connectors are used with no overlapping cables.
    • Once the watch is open, the battery is easy to access and replace.
    • Opening the watch is doable, but not easy, due to the back cover's tight fit and use of adhesive instead of gaskets.
    • The only separately-accessible part on the back cover (the loudspeaker) requires some digging, and is glued into a tight recess.
    • A broken display requires replacing the main watch case which houses the screen.
    • The back cover and attached sensors requires a complete replacement if any of its components fails.
    Onarılabilirlik Puanı
    5
    Onarılabilirlik 10 üzerinden 5
    (10 en kolay onarılabileni)
Tobias Isakeit
117.763 İtibar
188 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.545 adet Kılavuz yazıldı
2 Yorum
When a tiny smartwatch has as much RAM and more storage than the Android tablet you use every day.
tramcrazy - Yanıt
Bnas noches nesecito reparar mi reloj inteligente hawei was 3 tiene dañada la rueda lateral como puedo hacer
Dikson Mogollon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 63
Son 30 gün: 361
Her zaman: 14,108
