Ana içeriğe geç
IBM ThinkPad T42 Teardown
Neye ihtiyacın var
  1. IBM ThinkPad T42 Teardown, Complete Disassembly: adım 1, 3 resimden 1. IBM ThinkPad T42 Teardown, Complete Disassembly: adım 1, 3 resimden 2. IBM ThinkPad T42 Teardown, Complete Disassembly: adım 1, 3 resimden 3.
    • Removing the battery
    • Unplug the power cable before removing the battery.
    • Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
    • Grasp the battery and pull it straight out - not at an angle.
  2. IBM ThinkPad T42 Teardown: adım 2, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 2, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 2, 3 resimden 3.
    • Removing the Hard Drive
    • Unscrew the screw holding the Hard Drive slot in place.
    • Pull the hard drive out with the help of pictured ridges. Cautiously maneuver it out - it might help to open the display slightly.
  3. IBM ThinkPad T42 Teardown: adım 3, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 3, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 3, 3 resimden 3.
    • Removing the Optical Drive
    • Remove the screw holding the optical drive on the underside of the laptop
    • Push the small slider to unlock position, a tab will automatically pop out.
    • Pull tab to dislodge the optical drive, then pull the drive out.
  4. IBM ThinkPad T42 Teardown: adım 4, 2 resimden 1. IBM ThinkPad T42 Teardown: adım 4, 2 resimden 2.
    • Removing Memory Cover/Replacing RAM
    • Unscrew the pictured screwed holding the memory cover in place.
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up. -picture of RAM inside -
    • Pull the stick out carefully. - Picture of the RAM stick -
  5. IBM ThinkPad T42 Teardown: adım 5, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 5, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 5, 3 resimden 3.
    • Removing Rear Cover
    • Unscrew the rest of the screws on the underside of the T42.
    • Unscrew the 4 screws on either side the rear end of the laptop.
    • Note: for ease of reassembly, keep track of which screws go where.
    • [ a line-drawing version is included so it can be printed and screws can be taped on ]
  6. IBM ThinkPad T42 Teardown: adım 6, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 6, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 6, 3 resimden 3.
    • Removing Keyboard and Trackpad
    • Flip the laptop over and open the display carefully - the keyboard, palm rest and bezel will be loose.
    • Maneuver the palm rest away from the keyboard carefully, both the keyboard and palm rest/trackpad will come off together.
    • **WARNING** Both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  7. IBM ThinkPad T42 Teardown: adım 7, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 7, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 7, 3 resimden 3.
    • From here you can remove multiple components.
    • Removing Wi-Fi Card
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
    • Carefully pull it out.
  8. IBM ThinkPad T42 Teardown: adım 8, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 8, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 8, 3 resimden 3.
    • Removing Mini-PCI Port
    • Unscrew the screw holding the port's bracket down, then remove the bracket.
    • Carefully disconnect it from the motherboard.
  9. IBM ThinkPad T42 Teardown: adım 9, 2 resimden 1. IBM ThinkPad T42 Teardown: adım 9, 2 resimden 2.
    • Removing Top Plastic
    • Starting from the bottom right, carefully pry off the bezel. Use a small, flathead screwdriver if necessary.
  10. IBM ThinkPad T42 Teardown: adım 10, 2 resimden 1. IBM ThinkPad T42 Teardown: adım 10, 2 resimden 2.
    • Removing the Display
    • To remove the display, unscrew the screws holding it down. Along with the one pictured, there is another one on the top right edge.
    • Carefully unplug the its connection with the motherboard.
    • Now it will be free to move. Carefully maneuver it out.
  11. IBM ThinkPad T42 Teardown: adım 11, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 11, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 11, 3 resimden 3.
    • Removing Lower Bracket
    • The bracket will be free to move, so remove it.
    • Then remove the small rubber piece covering the small battery.
  12. IBM ThinkPad T42 Teardown: adım 12, 2 resimden 1. IBM ThinkPad T42 Teardown: adım 12, 2 resimden 2.
    • Removing Speakers
    • This component is free to move, so disconnect it's connector and pull it out carefully.
  13. IBM ThinkPad T42 Teardown: adım 13, 2 resimden 1. IBM ThinkPad T42 Teardown: adım 13, 2 resimden 2.
    • Removing Fan
    • Unscrew the three shown screws, then unplug its connection with the motherboard.
    • **Since both the processor and graphics processor unit are attached to this fan with thermal paste, removing the fan might require some force and a flathead screwdriver to separate the paste from the fan.
  14. IBM ThinkPad T42 Teardown: adım 14, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 14, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 14, 3 resimden 3.
    • Removing Processor
    • After removal of the fan, you have access to the processor. Locate its locking mechanism.
    • Use a flat head screwdriver and twist it carefully to the "unlocked" position.
    • Carefully pull the processor out.
    • ***CAUTION - If replacing the processor, make sure the small arrow on the corner aligns with socket.
  15. IBM ThinkPad T42 Teardown: adım 15, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 15, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 15, 3 resimden 3.
    • Removing Modem Daughter Card
    • Unscrew three phillips screws as shown.
    • The connector cables are wrapped around components for organization so follow these, unplug them and carefully pull them free.
    • Then remove the bracket that was sitting beneath it.
  16. IBM ThinkPad T42 Teardown: adım 16, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 16, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 16, 3 resimden 3.
    • Removing Metal Casing
    • Unscrew the Philips head screws as shown
    • It is attached to the smaller black plastic piece below it - carefully maneuver both of them out at the same time.
  17. IBM ThinkPad T42 Teardown: adım 17, 1 resimden 1.
    • Removing Plastic
    • This will be free to move, so pull it out.
  18. IBM ThinkPad T42 Teardown: adım 18, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 18, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 18, 3 resimden 3.
    • Removing Motherboard
    • Unscrew Phillips screws shown in red in the picture.
    • Unplug the connector (shown in turquoise)
    • Carefully remove the board
  19. IBM ThinkPad T42 Teardown: adım 19, 3 resimden 1. IBM ThinkPad T42 Teardown: adım 19, 3 resimden 2. IBM ThinkPad T42 Teardown: adım 19, 3 resimden 3.
    • Congratulations
    • Now you're left with the motherboard and the bottom casing
    • This is as far as the teardown goes.
Sonuç
To reassemble your device, follow these instructions in reverse order. Remember when reassembling to apply a thin layer of thermal compound on the CPU block.
17 farklı kişi bu kılavuzu tamamladı.
eric
591 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
35 adet Kılavuz yazıldı
2 Yorum
Excelent, it help me so much.
MarhezCN - Yanıt
Great guide on how to take apart a computer!
Gabriel Pettis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 98
Her zaman: 39,289
