Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Disassembly outline
  1. Battery
    • Hard Drive
    • Optical Drive
  2. Memory Cover
    • RAM Memory
  3. Keyboard/Trackpad/Top Cover
    • Mini-PCI Slot
    • Wi-Fi Card
    • Internal Battery
    • Display
  4. Side Bezel
    • Video Card / Fan
      • Processor
  5. Metal Casings
  6. Plastics
    • Motherboard
  1. Removing the battery Unplug the power cable before removing the battery. Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
    • Removing the battery
    • Unplug the power cable before removing the battery.
    • Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
    • Grasp the battery and pull it straight out - not at an angle.
  2. Removing the Hard Drive Unscrew the screw holding the Hard Drive slot in place. Pull the hard drive out with the help of pictured ridges. Cautiously maneuver it out - it might help to open the display slightly.
    • Removing the Hard Drive
    • Unscrew the screw holding the Hard Drive slot in place.
    • Pull the hard drive out with the help of pictured ridges. Cautiously maneuver it out - it might help to open the display slightly.
  3. Removing the Optical Drive Remove the screw holding the optical drive on the underside of the laptop Push the small slider to unlock position, a tab will automatically pop out.
    • Removing the Optical Drive
    • Remove the screw holding the optical drive on the underside of the laptop
    • Push the small slider to unlock position, a tab will automatically pop out.
    • Pull tab to dislodge the optical drive, then pull the drive out.
  4. Removing Memory Cover/Replacing RAM Unscrew the pictured screwed holding the memory cover in place.
    • Removing Memory Cover/Replacing RAM
    • Unscrew the pictured screwed holding the memory cover in place.
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up. -picture of RAM inside -
    • Pull the stick out carefully. - Picture of the RAM stick -
  5. Removing Rear Cover Unscrew the rest of the screws on the underside of the T42. Unscrew the 4 screws on either side the rear end of the laptop.
    • Removing Rear Cover
    • Unscrew the rest of the screws on the underside of the T42.
    • Unscrew the 4 screws on either side the rear end of the laptop.
    • Note: for ease of reassembly, keep track of which screws go where.
    • [ a line-drawing version is included so it can be printed and screws can be taped on ]
    I wouldn't start with a complete removal of all screws. The IBM/Lenovo hardware manual shows which screws to remove to get to what part.
    Yishai Sered - Yanıt
  6. Removing Keyboard and Trackpad Flip the laptop over and open the display carefully - the keyboard, palm rest and bezel will be loose. Maneuver the palm rest away from the keyboard carefully, both the keyboard and palm rest/trackpad will come off together.
    • Removing Keyboard and Trackpad
    • Flip the laptop over and open the display carefully - the keyboard, palm rest and bezel will be loose.
    • Maneuver the palm rest away from the keyboard carefully, both the keyboard and palm rest/trackpad will come off together.
    • **WARNING** Both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  7. From here you can remove multiple components. Removing Wi-Fi Card To remove Wi-Fi card, first disconnect both display wires on the top right.
    • From here you can remove multiple components.
    • Removing Wi-Fi Card
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
    • Carefully pull it out.
  8. Removing Mini-PCI Port Unscrew the screw holding the port's bracket down, then remove the bracket. Carefully disconnect it from the motherboard.
    • Removing Mini-PCI Port
    • Unscrew the screw holding the port's bracket down, then remove the bracket.
    • Carefully disconnect it from the motherboard.
  9. Removing Top Plastic Starting from the bottom right, carefully pry off the bezel. Use a small, flathead screwdriver if necessary.
    • Removing Top Plastic
    • Starting from the bottom right, carefully pry off the bezel. Use a small, flathead screwdriver if necessary.
  10. Removing the Display To remove the display, unscrew the screws holding it down. Along with the one pictured, there is another one on the top right edge.
    • Removing the Display
    • To remove the display, unscrew the screws holding it down. Along with the one pictured, there is another one on the top right edge.
    • Carefully unplug the its connection with the motherboard.
    • Now it will be free to move. Carefully maneuver it out.
    el cable bt como lo conecto el monitor a la placa
    Fernando - Yanıt
  11. Removing Lower Bracket The bracket will be free to move, so remove it. Then remove the small rubber piece covering the small battery.
    • Removing Lower Bracket
    • The bracket will be free to move, so remove it.
    • Then remove the small rubber piece covering the small battery.
  12. Removing Speakers This component is free to move, so disconnect it's connector and pull it out carefully.
    • Removing Speakers
    • This component is free to move, so disconnect it's connector and pull it out carefully.
  13. Removing Fan Unscrew the three shown screws, then unplug its connection with the motherboard.
    • Removing Fan
    • Unscrew the three shown screws, then unplug its connection with the motherboard.
    • **Since both the processor and graphics processor unit are attached to this fan with thermal paste, removing the fan might require some force and a flathead screwdriver to separate the paste from the fan.
  14. Removing Processor After removal of the fan, you have access to the processor. Locate its locking mechanism. Use a flat head screwdriver and twist it carefully to the "unlocked" position.
    • Removing Processor
    • After removal of the fan, you have access to the processor. Locate its locking mechanism.
    • Use a flat head screwdriver and twist it carefully to the "unlocked" position.
    • Carefully pull the processor out.
    • ***CAUTION - If replacing the processor, make sure the small arrow on the corner aligns with socket.
  15. Removing Modem Daughter Card Unscrew three phillips screws as shown. The connector cables are wrapped around components for organization so follow these, unplug them and carefully pull them free.
    • Removing Modem Daughter Card
    • Unscrew three phillips screws as shown.
    • The connector cables are wrapped around components for organization so follow these, unplug them and carefully pull them free.
    • Then remove the bracket that was sitting beneath it.
  16. Removing Metal Casing Unscrew the Philips head screws as shown It is attached to the smaller black plastic piece below it - carefully maneuver both of them out at the same time.
    • Removing Metal Casing
    • Unscrew the Philips head screws as shown
    • It is attached to the smaller black plastic piece below it - carefully maneuver both of them out at the same time.
    Does this give you open access to the IDE port?
    Evan Nayee - Yanıt
  17. Removing Plastic
    • Removing Plastic
    • This will be free to move, so pull it out.
  18. Removing Motherboard Unscrew Phillips screws shown in red in the picture. Unplug the connector (shown in turquoise)
    • Removing Motherboard
    • Unscrew Phillips screws shown in red in the picture.
    • Unplug the connector (shown in turquoise)
    • Carefully remove the board
  19. Congratulations Now you're left with the motherboard and the bottom casing This is as far as the teardown goes.
    • Congratulations
    • Now you're left with the motherboard and the bottom casing
    • This is as far as the teardown goes.
Sonuç
To reassemble your device, follow these instructions in reverse order. Remember when reassembling to apply a thin layer of thermal compound on the CPU block.
15 farklı kişi bu kılavuzu tamamladı.
eric
537 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
30 adet Kılavuz yazıldı
2 Yorum
Excelent, it help me so much.
MarhezCN - Yanıt
Great guide on how to take apart a computer!
Gabriel Pettis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 25
Son 30 gün: 149
Her zaman: 35,707
