Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Jolla cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Jolla Teardown, Jolla: adım 1, 1 resimden 1.
    • Turn it off!
  2. Jolla Teardown, Back cover: adım 2, 3 resimden 1. Jolla Teardown, Back cover: adım 2, 3 resimden 2. Jolla Teardown, Back cover: adım 2, 3 resimden 3.
    • Remove the back cover by pulling up from the bottom right hand corner. Remove the bottom first and then the sides.
  3. Jolla Teardown, Battery, sim card and MicroSD Card: adım 3, 2 resimden 1. Jolla Teardown, Battery, sim card and MicroSD Card: adım 3, 2 resimden 2.
    • Remove battery from the small space near the bottom of the phone.
    • Remove the sim card by pulling the plastic flap to the right and pulling/pushing the sim card downwards.
    • Remove the MicroSD card by pushing up from the bottom until it clicks. It will then ping down.
  4. Jolla Teardown: adım 4, 1 resimden 1.
    • Remove 11 T5 screws.
  5. Jolla Teardown, Remove the back frame: adım 5, 3 resimden 1. Jolla Teardown, Remove the back frame: adım 5, 3 resimden 2. Jolla Teardown, Remove the back frame: adım 5, 3 resimden 3.
    • Pull up from the bottom corners, remove the bottom first and then the sides.
    • The volume and power buttons may fall out at this point. Don't lose them.
  6. Jolla Teardown, Inner frame.: adım 6, 3 resimden 1. Jolla Teardown, Inner frame.: adım 6, 3 resimden 2. Jolla Teardown, Inner frame.: adım 6, 3 resimden 3.
    • Remove this T5 screw from the bottom left hand side. This is the only screw holding in the inner frame.
    • The frame should lift out and up from the phone.
    • If your volume button and power button haven't fallen out yet, they will now.
  7. Jolla Teardown, Connectors: adım 7, 2 resimden 1. Jolla Teardown, Connectors: adım 7, 2 resimden 2.
    • Two connectors on the top right hand side.
    • 3 connectors on the right hand side about half way down the phone.
  8. Jolla Teardown, Antenna: adım 8, 3 resimden 1. Jolla Teardown, Antenna: adım 8, 3 resimden 2. Jolla Teardown, Antenna: adım 8, 3 resimden 3.
    • Remove one end from here.
    • The other end can be removed here.
  9. Jolla Teardown, Circuit board: adım 9, 3 resimden 1. Jolla Teardown, Circuit board: adım 9, 3 resimden 2. Jolla Teardown, Circuit board: adım 9, 3 resimden 3.
    • The circuit board is held in place by one T5 screw.
    • Use a spudger to gently pry the circuit board upwards. Do this on both sides.
    • It should lift out quite easily.
  10. Jolla Teardown, Small circuit board: adım 10, 3 resimden 1. Jolla Teardown, Small circuit board: adım 10, 3 resimden 2. Jolla Teardown, Small circuit board: adım 10, 3 resimden 3.
    • The second circuit board can be removed after removing the connector attached to it and gently prying it off. It's fixed in place by a small amount of glue.
  11. Jolla Teardown, Cameras: adım 11, 3 resimden 1. Jolla Teardown, Cameras: adım 11, 3 resimden 2. Jolla Teardown, Cameras: adım 11, 3 resimden 3.
    • Main camera.
    • Secondary camera.
  12. Jolla Teardown, Done!: adım 12, 1 resimden 1.
    • I won't be removing the screen in this teardown as replacement screens for the Jolla phone are not very easily available at the moment.
Shannon McWilliam
25 İtibar
1 Kılavuz yazıldı
Bir Yorum
So far so easy. I might be able to get hold of a new Screen/Digitizer for my good old Jolla (finally removing this annoying spider app ;-) ). Would be nice if you could say a few words about going on from where you stoped. It seems to me that the rest is more or less one piece being molded together or something. What else is there to remove, besides small parts like earpiece, mic, audioconnector, flat cables, etc.
Is the digitizer-glass just glued in so I could pry off the pieces of mine and replace it with a new one?
Would be very nice to hear from you and thanks a lot for the tear down, was very helpfull so far.
FYI: Spare parts available at maxbhi.com, though I don't trust that shop very much ;-)
Matthias Twittmann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 108
Her zaman: 5,017
