Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Kindle Fire HD 6 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Kindle Fire HD 6 Teardown, Kindle Fire HD 6 Teardown: adım 1, 1 resimden 1.
    • One hundred dollars. One Benjamin. A single C-note. That's the cost of a Amazon's New Kindle Fire HD 6. Let's see what your not-so-hard-earned cash buys you:
    • 6" high definition touchscreen with 1280 x 800 resolution at 252 ppi
    • Quad-Core processor with two cores running at 1.5 GHz and two cores at 1.2 GHz
    • 1 GB of RAM
    • 8 GB (4.5 GB available to user) or 16 GB (11.6 GB available to user) of internal storage
    • 802.11b, 802.11g, or 802.11n Single-antenna Wi-Fi + Accelerometer + Gyroscope + Bluetooth
    • VGA Front-facing Camera + 2.0 MP Rear-facing HD camera
  2. Kindle Fire HD 6 Teardown: adım 2, 3 resimden 1. Kindle Fire HD 6 Teardown: adım 2, 3 resimden 2. Kindle Fire HD 6 Teardown: adım 2, 3 resimden 3.
    • Good news, everyone! You won't need anything fancier than an opening pick to crack this case. Plastic clips and no adhesive secure the panel.
    • This looks familiar. It seems the Fire HD 6 is just a small Kindle Fire.
    • Already a very simple device, the Fire has undergone some serious streamlining internally (not to mention shrinking externally).
    • It looks to us like the motherboard, rear camera, battery, and speaker are all clearly available for easy removal...
  3. Kindle Fire HD 6 Teardown: adım 3, 3 resimden 1. Kindle Fire HD 6 Teardown: adım 3, 3 resimden 2. Kindle Fire HD 6 Teardown: adım 3, 3 resimden 3.
    • Or so we thought. The battery, while up on top and otherwise ready to roll, is suffering from separation anxiety.
    • Dear Amazon, can you please tone down the Kindle battery glue? Thank you.
    • Even with our plastic card, we had to use excessive force to pry the battery out.
    • The 3.7 V, 3400 mAh (12.6 Wh) Lithium-ion Polymer battery in the Kindle Fire HD 6 is pretty hefty at 60 grams—about one fifth of the total weight of the Fire.
    • Amazon promises about 8 hours of use, but warns that "results may vary."
    • For the record, the HDX 7" clocks in at 17.29 Wh and the original 7" Fire tablet had a 16.28 Wh capacity.
  4. Kindle Fire HD 6 Teardown: adım 4, 3 resimden 1. Kindle Fire HD 6 Teardown: adım 4, 3 resimden 2. Kindle Fire HD 6 Teardown: adım 4, 3 resimden 3.
    • Moving right along on the "removing modular components" train, we pull out the speaker, rear-facing camera, and finally (after all of that effort) the motherboard.
    • The 2.0 MP rear-facing camera is...well...a camera.
    • Which is great if you ever wanted 2005 flip-phone photography in a new unwieldy format.
    • According to Amazon, the rear-facing camera is capable of taking high-resolution photos (including panorama and HDR photos) and capturing 1080p HD video.
  5. Kindle Fire HD 6 Teardown: adım 5, 1 resimden 1.
    • These are the ICs that ignite the Kindle Fire HD 6:
    • SK Hynix H5TC4G63AFR 4 Gb (512 MB) DDR3L SDRAM (512 MB x 2 = 1 GB)
    • Toshiba THGBMBG6D1KBAIL 8 GB e-MMC NAND Flash
    • MediaTek MT8135V Applications Processor
    • MediaTek MT6397A 1425-ANAH EC4 AW80H
    • MediaTek MT6628TP Wi-Fi/Bluetooth Controller
    • SlimPort ANX3618 SlimPort Connectivity IC
    • Cypress Semiconductor CY8CTMA4 63-56LQI 1419 F 04 CYP620476
  6. Kindle Fire HD 6 Teardown: adım 6, 1 resimden 1.
    • A few straggler ICs reside on the back side of the motherboard:
    • Maxim Integrated MAX97236 Audio Amplifier with Jack Detection
    • M651 X171C1 L146
    • Novatek NT50357 1422-AD D7MN91
  7. Kindle Fire HD 6 Teardown: adım 7, 2 resimden 1. Kindle Fire HD 6 Teardown: adım 7, 2 resimden 2.
    • Look ma, no optical adhesive! It's been a while since we've seen a tablet display come apart into non-fused glass and display components.
    • Definitely a design carryover from the original Fire.
    • The 6 inch, 1280 x 800 pixels (252 ppi) display is provided by LG Display.
    • The display glass assembly contains the digitizer and the VGA front-facing camera.
  8. Kindle Fire HD 6 Teardown: adım 8, 2 resimden 1. Kindle Fire HD 6 Teardown: adım 8, 2 resimden 2.
    • Fire HD 6 Repairability Score: 8 out of 10 (10 is easiest to repair).
    • The rear case is very easy to open, granting trouble-free access to the internals.
    • All the fasteners found inside are T5 Torx screws—one non-proprietary screwdriver is all you need.
    • Simplistic design and limited functionality means fewer components and less headache for disassembly.
    • Battery adhesive is much stronger than necessary, which makes disassembly hazardous.
    • The glass panel is fused to the front plastic frame, meaning a heat gun is required for replacing cracked glass (or you have to replace both components together).
    • Lack of available replacement parts has limited repair options in other Kindle models. We can only hope this model doesn't share the same fate.
    Why does step 8 say that the glass panel is fused, while step 7 applaudes the non-fused nature?
    Peterdk - Yanıt
    the article is talking about the frame on the outside
    Nicholas Larimer -
    Glass is fused to bezel, not to the display, that's noteworthy.
    gdrgry34fsdf324 - Yanıt
    HOW on earth did you find a screen replacement for this Kindle Fire HD6? It's like Jimmy Hoffa. Nobody can find it.
    traviskatrinacheek - Yanıt
8Kılavuz Yorumları
Simplistic refers to treating somthing as much simpler than it is.
In this case, calling partial disassembly into a few major subassembles, one of which contains more than 95% of the content of the device, a teardown, is a simplistic understanding of what a teardown is.
The design is clean and straight forward, but not simple, except perhaps to someone would would regard an automobile engine/transmission assembly as a component to be replaced rather than repaired.
Hey guys, does anyone know where I can purchase a glass replacement or the entire front glass housing? My son dropped it while coming out of the car, and the entire glass shattered. Thanks in advance :)
Anibal Alanis - Yanıt
hey Anibal Alanis, you can buy it on Amazon or online shopping, check on google
http://hargasmartphone.id/harga-apple-ip...
irwansyah10 -
Nobody has these replacement screens. Amazon suggested just to buy a new one, of course! maybe in a few months, China will start cranking them out and I can finally fix my son's unit without spending $100
christy cunningham - Yanıt
I don't know what if anything you did about this , as your post is 11 months old at this time, but I bought this same device from a neighbor for $20. It has a cracked screen. Cost to replace it? $100
cackalackyhacky -
I'm so upset my son's tablet fell between the crack of our couch and the screen cracked.... Didn't even hit the floor and it's broken..... And the way they advertise it should last through anything!!! What a joke!!! And he's only had it for 3months and of course nothing Amazon can do.....
April - Yanıt
sounds like a fake
iankid -
The NT50357 1422-AD D7MN91 chip is a Novatek IC of some sort
CTCL - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 34,288
