Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Kyocera Oystr cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Kyocera Oystr Teardown, Removing the battery: adım 1, 3 resimden 1. Kyocera Oystr Teardown, Removing the battery: adım 1, 3 resimden 2. Kyocera Oystr Teardown, Removing the battery: adım 1, 3 resimden 3.
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: adım 2, 3 resimden 1. Kyocera Oystr Teardown, Removing screws from screen: adım 2, 3 resimden 2. Kyocera Oystr Teardown, Removing screws from screen: adım 2, 3 resimden 3.
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: adım 3, 3 resimden 1. Kyocera Oystr Teardown, Exposing internal components: adım 3, 3 resimden 2. Kyocera Oystr Teardown, Exposing internal components: adım 3, 3 resimden 3.
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: adım 4, 1 resimden 1.
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: adım 5, 3 resimden 1. Kyocera Oystr Teardown, Screen removal: adım 5, 3 resimden 2. Kyocera Oystr Teardown, Screen removal: adım 5, 3 resimden 3.
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: adım 6, 1 resimden 1.
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
24 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Stout, Team 5-7, Zhou Fall 2011 UW Stout, Team 5-7, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S5G7
2 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
where do I get a new screen?
LARS ANDERSEN - Yanıt
where do i get a new screen
thanks
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 4,360
