Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. LG GW300 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. LG GW300 Teardown, LG GW300 Teardown: adım 1, 1 resimden 1.
    • Found this phone lying around, so decided to make a teardown of it!
  2. LG GW300 Teardown: adım 2, 1 resimden 1.
    • First, remove the backplate by pushing the button at the top of the back of the phone.
  3. LG GW300 Teardown: adım 3, 3 resimden 1. LG GW300 Teardown: adım 3, 3 resimden 2. LG GW300 Teardown: adım 3, 3 resimden 3.
    • From here there are six screws we have to remove.
    • But first... lemme take a battery out!
  4. LG GW300 Teardown: adım 4, 1 resimden 1.
    • Get a thin opening tool and slide it around the bezel of the device.
    • Make sure you put it in the correct place, behind the silver bezel of the front of the phone!
  5. LG GW300 Teardown: adım 5, 1 resimden 1.
    • The front and back of the device should separate.
    • Two buttons should come off after you have removed the back.
    • This is the rear speaker.
  6. LG GW300 Teardown: adım 6, 3 resimden 1. LG GW300 Teardown: adım 6, 3 resimden 2. LG GW300 Teardown: adım 6, 3 resimden 3.
    • Both of these buttons need to be pried from the front casing to allow the mainboard to come away from the front housing.
    • These buttons are soldered to the mainboard so make sure you don't break them!
    • The front speaker also has to be pried from the front housing.
  7. LG GW300 Teardown: adım 7, 2 resimden 1. LG GW300 Teardown: adım 7, 2 resimden 2.
    • The main board can then be lifted from the front housing.
  8. LG GW300 Teardown: adım 8, 1 resimden 1.
    • The buttons on the front housing can then be pushed out through the back of the housing.
  9. LG GW300 Teardown: adım 9, 2 resimden 1. LG GW300 Teardown: adım 9, 2 resimden 2.
    • The EMI shield can be removed by unclipping the clips on the side of the device.
  10. LG GW300 Teardown: adım 10, 2 resimden 1. LG GW300 Teardown: adım 10, 2 resimden 2.
    • In the centre of the picture is the vibration module. It can be unclipped to remove it.
  11. LG GW300 Teardown: adım 11, 3 resimden 1. LG GW300 Teardown: adım 11, 3 resimden 2. LG GW300 Teardown: adım 11, 3 resimden 3.
    • The LCD ribbon cable and connector are under a plastic sheet that has to be removed.
    • The ribbon cable can then be take out of the connector
    • The ribbon connector is very fragile, so be careful when lifting the lever.
  12. LG GW300 Teardown: adım 12, 2 resimden 1. LG GW300 Teardown: adım 12, 2 resimden 2.
    • Use a thin opening tool to separate the LCD from the main board.
    • Do this slowly and carefully as the screen can easily crack or bleed.
  13. LG GW300 Teardown: adım 13, 1 resimden 1.
    • Chip inspection time!
    • Mediatek ARM MT6A01AA
    • Samsung K5D1H12ACC-A075 NAND flash memory
    • Skyworks Solutions SKY77524-15
    • CSR 51E130A14U
James
185 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Now if only I could find the datasheet/pinout for the "Mediatek ARM MT6A01AA"...
River Saxton - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,457
