Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. LG Optimus L9 P769 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. LG Optimus L9 P769 Teardown, LG Optimus L9 P769 Teardown: adım 1, 2 resimden 1. LG Optimus L9 P769 Teardown, LG Optimus L9 P769 Teardown: adım 1, 2 resimden 2.
    • Here's what LG's L9 P769 holds hardware-wise:
    • Dual-core 1.0 GHz CPU
    • 4.5 inch IPS LCD with a resolution of 540 x 960 pixels
    • 4 GB of internal storage
    • 5MP Primary camera and VGA front facing camera
    • Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, hotspot, DLNA
  2. LG Optimus L9 P769 Teardown: adım 2, 1 resimden 1.
    • Power off the device and gently lift the battery cover off to access the battery
  3. LG Optimus L9 P769 Teardown: adım 3, 1 resimden 1.
    • Lift and remove the battery from the notch in the edge of the battery compartment
  4. LG Optimus L9 P769 Teardown: adım 4, 2 resimden 1. LG Optimus L9 P769 Teardown: adım 4, 2 resimden 2.
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using the PH000 headtype
  5. LG Optimus L9 P769 Teardown: adım 5, 2 resimden 1. LG Optimus L9 P769 Teardown: adım 5, 2 resimden 2.
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  6. LG Optimus L9 P769 Teardown: adım 6, 2 resimden 1. LG Optimus L9 P769 Teardown: adım 6, 2 resimden 2.
    • Carefully remove vibration and speaker module using the prying tool
  7. LG Optimus L9 P769 Teardown: adım 7, 3 resimden 1. LG Optimus L9 P769 Teardown: adım 7, 3 resimden 2. LG Optimus L9 P769 Teardown: adım 7, 3 resimden 3.
    • Remove both connections of the antenna by pulling up with tweezers
  8. LG Optimus L9 P769 Teardown: adım 8, 3 resimden 1. LG Optimus L9 P769 Teardown: adım 8, 3 resimden 2. LG Optimus L9 P769 Teardown: adım 8, 3 resimden 3.
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  9. LG Optimus L9 P769 Teardown: adım 9, 2 resimden 1. LG Optimus L9 P769 Teardown: adım 9, 2 resimden 2.
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  10. LG Optimus L9 P769 Teardown: adım 10, 1 resimden 1.
    • Remove screw at top of phone to release speaker with PH000 screwdriver
  11. LG Optimus L9 P769 Teardown: adım 11, 3 resimden 1. LG Optimus L9 P769 Teardown: adım 11, 3 resimden 2. LG Optimus L9 P769 Teardown: adım 11, 3 resimden 3.
    • Use a small prying tool to release all motherboard connections.
  12. LG Optimus L9 P769 Teardown: adım 12, 1 resimden 1.
    • Remove rear facing camera by using the small prying tool
  13. LG Optimus L9 P769 Teardown: adım 13, 2 resimden 1. LG Optimus L9 P769 Teardown: adım 13, 2 resimden 2.
    • Gently lift the motherboard with small prying tool to remove and set aside
  14. LG Optimus L9 P769 Teardown: adım 14, 1 resimden 1.
    • Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
    • Do not force open as the latches attaching the digitizer to the chassis as they are easily damaged.
  15. LG Optimus L9 P769 Teardown: adım 15, 2 resimden 1. LG Optimus L9 P769 Teardown: adım 15, 2 resimden 2.
    • Carefully remove the digitizer from case by sliding out connected ribbon cable
  16. LG Optimus L9 P769 Teardown: adım 16, 1 resimden 1.
    • Use a small prying tool to detach the screen circuitry from the case
  17. LG Optimus L9 P769 Teardown: adım 17, 3 resimden 1. LG Optimus L9 P769 Teardown: adım 17, 3 resimden 2. LG Optimus L9 P769 Teardown: adım 17, 3 resimden 3.
    • Remove the remaining circuitry utilizing a smaller prying tool or a small flathead screwdriver
    • Carefully slide out circuity to remove phone display
  18. LG Optimus L9 P769 Teardown: adım 18, 1 resimden 1.
    • Use tweezers to disconnect the 3.5mm headphone jack from the phone
  19. LG Optimus L9 P769 Teardown: adım 19, 3 resimden 1. LG Optimus L9 P769 Teardown: adım 19, 3 resimden 2. LG Optimus L9 P769 Teardown: adım 19, 3 resimden 3.
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  20. LG Optimus L9 P769 Teardown: adım 20, 1 resimden 1.
    • Full tear-down and recommended tools for procedure
Kayden G
272 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Harley Spring 2017 IUPUI, Team S2-G1, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 1,788
