Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. LG T310 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. LG T310 Teardown, LG T310 Teardown: adım 1, 1 resimden 1.
    • Slide back cover down with hand in the direction of the arrow on the cover
    • Gently remove back cover
    • Remove the battery by inserting the plastic opening tool into the groove and gently prying it out
  2. LG T310 Teardown: adım 2, 2 resimden 1. LG T310 Teardown: adım 2, 2 resimden 2.
    • Remove all of the screws on the back of the phone using a Phillips head screw driver
    • Slide out the SIM card from the phone
  3. LG T310 Teardown: adım 3, 1 resimden 1.
    • Using the plastic opening tool, pry off the shell of the phone, revealing the motherboard
  4. LG T310 Teardown: adım 4, 2 resimden 1. LG T310 Teardown: adım 4, 2 resimden 2.
    • Using the plastic opening tool, gently pry the motherboard out (while doing this be sure not to pull on the mother board as it is attached to the touch screen)
    • Starting at the top left corner of the screen (with phone face down), insert your plastic opening tool and work down the left side.
    • The screen should be loose now making it possible to remove it from the case by hand (try not to touch the actual screen, only the side or back).
    • This completes the tear down of your LG-T310 Cookie
Andrew
116 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 1,467
