Ana içeriğe geç
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. LG VX3200 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. LG VX3200 Teardown, Battery: adım 1, 1 resimden 1.
    • Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
    • Pull back panel toward bottom of phone.
  2. LG VX3200 Teardown: adım 2, 1 resimden 1.
    • From the lip on the top of the battery, lift it out of the phone.
  3. LG VX3200 Teardown, LG VX3200 Teardown: adım 3, 1 resimden 1.
    • Remove the five screws from the back panel, under the battery.
    • There is a hidden screw under the rubber pad next to the antenna. To remove this pad use a screwdriver to pry out rubber.
  4. LG VX3200 Teardown: adım 4, 1 resimden 1.
    • Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
    • There are 4 places where the panel snaps together to the main part of the phone.
    • By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
    • Don't be afraid to damage anything, the panel requires a bit of force to detach.
  5. LG VX3200 Teardown: adım 5, 1 resimden 1.
    • In order to remove the back panel of the screen half of the phone, you have to remove the 4 screws.
    • First, open the phone and remove the 4 rubber pads that are around the screen. you can use a small screwdriver or a pin to pop them out.
  6. LG VX3200 Teardown: adım 6, 1 resimden 1.
    • Remove the four screws using your Phillips head screwdriver.
  7. LG VX3200 Teardown: adım 7, 2 resimden 1. LG VX3200 Teardown: adım 7, 2 resimden 2.
    • Similar to removing the panel underneath the battery, you need to pry the colored panel off of the top half of the phone.
    • There are 4 snap-in points and some sticky tape holding the panel on. Starting on the side nearest the antenna, pry off the panel, moving slowly around the panel.
  8. LG VX3200 Teardown: adım 8, 2 resimden 1. LG VX3200 Teardown: adım 8, 2 resimden 2.
    • The logic board is only held on with 4 tabs. Simply pry from one side using a screwdriver, popping out the board.
    • Note that the logic board is still connected to the screen by an electrical ribbon.
  9. LG VX3200 Teardown: adım 9, 1 resimden 1.
    • The speakers are held in by a sticky glue. Be careful not to break any of the components, simply pry slowly from underneath until the speakers pop out.
  10. LG VX3200 Teardown: adım 10, 1 resimden 1.
    • To remove the screen, grab hold of one or more of the speakers and pry up using the connecting wire. The tape holding the screen in should lift up, and the screen should easily separate from the case.
  11. LG VX3200 Teardown: adım 11, 1 resimden 1.
    • Detaching the two halves of the phone from each other takes a bit of force.
    • With the phone open, pry from the right side of the hinge with a screwdriver. Using a bit of force, pull apart the two halves.
    • Be careful not to tear the ribbon connecting the logic board to the screen.
Bradley Hutchinson
42 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-9, Forte Winter 2010 Cal Poly, Team 5-9, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,451
