Ana içeriğe geç
LaCie Minimus Teardown
Neye ihtiyacın var
  1. LaCie Minimus Teardown, Hard Drive: adım 1, 1 resimden 1.
    • LaCie Minimus (2 TB hard drive)
  2. LaCie Minimus Teardown: adım 2, 3 resimden 1. LaCie Minimus Teardown: adım 2, 3 resimden 2. LaCie Minimus Teardown: adım 2, 3 resimden 3.
    • Turn the drive over, noting the black rubber strips. Carefully peel each strip off, to reveal a set of two phillips screws under each strip.
  3. LaCie Minimus Teardown: adım 3, 2 resimden 1. LaCie Minimus Teardown: adım 3, 2 resimden 2.
    • Remove the two sets of phillips screws and set them aside.
  4. LaCie Minimus Teardown: adım 4, 1 resimden 1.
    • Carefully push on the front, black faceplate to slide the drive and housing out of the case.
  5. LaCie Minimus Teardown: adım 5, 2 resimden 1. LaCie Minimus Teardown: adım 5, 2 resimden 2.
    • Note the label: Warranty Void If Seal Broken. In this case, we want to retrieve the data and do not care about the warranty. Remove the label, to expose one of the four total screws on the side to remove the internal drive.
  6. LaCie Minimus Teardown: adım 6, 2 resimden 1. LaCie Minimus Teardown: adım 6, 2 resimden 2.
    • Carefully remove the four screws holding the drive in the caddy, making sure that the hard drive does not slip out or damage the SATA controller card towards the rear of the case.
  7. LaCie Minimus Teardown: adım 7, 2 resimden 1. LaCie Minimus Teardown: adım 7, 2 resimden 2.
    • The drive is now removed. Use an external hard drive reader, etc., such as the Cavalry in the second picture, to hopefully access your drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Lance Wessel
530 İtibar
3 adet Kılavuz yazıldı
6 Yorum
Thank you !
We will need it ....
Giuseppedegioia - Yanıt
Drive inside say
5VDC / 12VDC - 0.5A 0.7A
But my replace say:
5VDC, 0,60A
12VDC, 0,45A
Is that OK or should I not change?
hlundstedt - Yanıt
thank you this was great help.
I have a problem where the usb port is broken on the inside of the hard drive. do you know what that piece is called? i need to buy a new one, not even sure if its possible to buy.
thank you
Jovan Popovic - Yanıt
its the first green rectangle shape that has the USB attatched to it which is broken.
sorry not really good with this stuff just trying to solve it
Thanks, very clear manual, helped me wel ! :)
Tomas Navratil - Yanıt
Top notch, thanks
objectdolphin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 7,756
