Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Lenovo Ideatab A1000 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 1, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 1, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 1, 3 resimden 3.
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 2, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 2, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 2, 3 resimden 3.
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 3, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 3, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 3, 3 resimden 3.
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  4. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 4, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 4, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 4, 3 resimden 3.
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  5. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 5, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 5, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 5, 3 resimden 3.
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  6. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 6, 3 resimden 1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 6, 3 resimden 2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: adım 6, 3 resimden 3.
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
191.341 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.541 adet Kılavuz yazıldı
2 Yorum
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - Yanıt
Thanks for this guide!
Pooshon Banerjee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 20
Her zaman: 14,225
