Giriş
Here is a video teardown of the ThinkPad T410s.
Below is a step by step teardown
Neye ihtiyacın var
Videoya Genel Bakış
Remove 14 retaining screws from back
The first 9 are required for bezel and touchpad removal .
M2 × 14 mm, wafer-head, nylon-coated (6)
M2 × 3 mm, wafer-head, nylon-coated (3)
The remaining need to be removed for base cover removal
M2 × 5 mm, wafer-head, nylon-coated (4)
M2 × 10 mm, wafer-head, nylon-coated (1)
Note: The FPC cable is attached on the underside of the keyboard bezel assembly. In some models, the Bluetooth daughter card is also attached on the underside of the keyboard bezel assembly.
Remove the two retaining screws on the bottom of the system.
M2.5 × 6 mm, wafer-head, nylon-coated (2)
Turn the system over and open the cover.
Unroute all the wires.
Remove the retaining screws.
Carefully lift the LCD panel up and out of the chass
5 Yorum
Uhm, sorry, what about the photos? I don't see any...
Still not seeing any photos accompanying the steps listed in the teardown.
The video shows a teardown of the T410s. It is a lot different from the T410.
