Giriş
Demo teardown at Maker-Faire 2010
Neye ihtiyacın var
After removing the single screw and sliding off the bottom panel, all that is left is the main circuit board.
Main Components
Barrel-plug power connection / CAT5 / Reset button
Power Control
Line-drivers (allow CAT5 cables to carry data for 100m)
RAM (2Mb) (Stores MAC tables, etc)
KS8695 ARM922 (ARM Core, 5 switchboards, tcp/ip/udp packet interface)
RAM (1Mb )
The 20PT1024X parts are Ethernet LAN magnetics from BothHandUSA, a common supplier of Ethernet magnetics (a term referring to an integrated monoblock containing per-wire-pair transformer and common-mode choke).
Bir Yorum
Thanks Ryan. Couldnt figure out how to get the case off until I checked here.
My BFSR41v2 teardown was identical so was able to replace the two 1000uf caps shown in step 5. The router gradually lost speed and finally quit altogether and wouldnt reset. Found the first cap had 5v AC across it and felt warm. The second cap was ok but replaced it anyway and the router is like new. BTW I was using it as a switch behind my wifi router to get more ports on my wired LAN.
Theres a good description of how to repurpose an old rouiter as a network switch on the How-to-geek site.
Cheers
