Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Linksys BEFW11S4 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Linksys BEFW11S4 Teardown, Linksys BEFW11S4 Teardown: adım 1, 1 resimden 1.
    • Waiting to be disassembled...
  2. Linksys BEFW11S4 Teardown: adım 2, 3 resimden 1. Linksys BEFW11S4 Teardown: adım 2, 3 resimden 2. Linksys BEFW11S4 Teardown: adım 2, 3 resimden 3.
    • Remove antennas.
    • Remove nuts and washers around antenna connectors.
    • Push in antenna connectors.
  3. Linksys BEFW11S4 Teardown: adım 3, 3 resimden 1. Linksys BEFW11S4 Teardown: adım 3, 3 resimden 2. Linksys BEFW11S4 Teardown: adım 3, 3 resimden 3.
    • Remove feet (with flat-head screwdriver, fingernails, etc).
    • Unscrew the screws.
  4. Linksys BEFW11S4 Teardown: adım 4, 2 resimden 1. Linksys BEFW11S4 Teardown: adım 4, 2 resimden 2.
    • Pull apart blue front from black back with a LOT of force.
    • Slide and pull up bottom. (Make sure the antenna connectors get through.)
  5. Linksys BEFW11S4 Teardown: adım 5, 1 resimden 1.
    • Twist and pull out antenna connector feeds.
  6. Linksys BEFW11S4 Teardown: adım 6, 3 resimden 1. Linksys BEFW11S4 Teardown: adım 6, 3 resimden 2. Linksys BEFW11S4 Teardown: adım 6, 3 resimden 3.
    • Pull up RF shield from motherboard.
    • Unscrew the motherboard from the bottom.
    • Push the motherboard forward (as in this picture) to unlatch it from the bottom.
    Really would have appreciated if the photos were in focus
    Dominik Meyer - Yanıt
  7. Linksys BEFW11S4 Teardown: adım 7, 2 resimden 1. Linksys BEFW11S4 Teardown: adım 7, 2 resimden 2.
    • Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
    • Push the card forward to deattach the pins.
    • Remove the card from the metal holdster.
  8. Linksys BEFW11S4 Teardown: adım 8, 1 resimden 1.
    • Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
    • Macronix 29F040QC-90
    • ISSI IS41C16100S-50K
    • SAMSUNG ARM S3C4510X01-QERO
    • RMC RTL8019AS
    • Bothhands FB2022
    • Bothhands 40ST1041E
    • Kendin KS8995. Kendin has since been bought by Micrel.
  9. Linksys BEFW11S4 Teardown: adım 9, 1 resimden 1.
    • Enjoy!
William McKinnerney
65 İtibar
1 Kılavuz yazıldı
2 Yorum
what is that card inside this router
hartiTube - Yanıt
Thank you. I accomplished this task. Except my antenna wires were soldered to the board.
Darren - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 9,036
