Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Linksys Velop WHW01 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Linksys Velop WHW01 Teardown, Unclip the top cover: adım 1, 2 resimden 1. Linksys Velop WHW01 Teardown, Unclip the top cover: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    • To unclip the top cover, insert a Jimmy at the seam and pry upwards.
  2. Linksys Velop WHW01 Teardown, Unscrew the outer case: adım 2, 2 resimden 1. Linksys Velop WHW01 Teardown, Unscrew the outer case: adım 2, 2 resimden 2.
    T6 Torx Screwdriver
    $9.99
    • Use a Torx T6 screwdriver to unscrew the two screws that were previously hidden under the top cover.
  3. Linksys Velop WHW01 Teardown, Remove the rubber strips: adım 3, 2 resimden 1. Linksys Velop WHW01 Teardown, Remove the rubber strips: adım 3, 2 resimden 2.
    Spudger
    $2.99
    • Use a Spudger to peel off the rubber strips at the base.
    • Make sure to not tear them apart.
  4. Linksys Velop WHW01 Teardown, Unscrew the base: adım 4, 3 resimden 1. Linksys Velop WHW01 Teardown, Unscrew the base: adım 4, 3 resimden 2. Linksys Velop WHW01 Teardown, Unscrew the base: adım 4, 3 resimden 3.
    T6 Torx Screwdriver
    $9.99
    • Use a Torx T6 screwdriver to unscrew the four screws that were under the rubber feet.
    • After removing the screws, the bottom cover can be lifted off.
  5. Linksys Velop WHW01 Teardown, Remove the outer cover: adım 5, 3 resimden 1. Linksys Velop WHW01 Teardown, Remove the outer cover: adım 5, 3 resimden 2. Linksys Velop WHW01 Teardown, Remove the outer cover: adım 5, 3 resimden 3.
    • Carefully pinch and pull up on the internal plastic bracket.
    • The main board, antenna and LED assembly should slide out without any force needed.
  6. Linksys Velop WHW01 Teardown, Remove the port cover: adım 6, 2 resimden 1. Linksys Velop WHW01 Teardown, Remove the port cover: adım 6, 2 resimden 2.
    • Lift up on the plastic surrounding the power input and ethernet ports.
    • You may need to give it a jiggle to come loose.
  7. Linksys Velop WHW01 Teardown, Unclip the WiFi antenna: adım 7, 1 resimden 1.
    Spudger
    $2.99
    • Unclip the WiFi antennas from the main board.
    • Use a Spudger to not cause any damage, these connectors can be very fragile!
  8. Linksys Velop WHW01 Teardown, Unscrew the antenna bracket: adım 8, 1 resimden 1.
    Phillips #00 Screwdriver
    $5.49
  9. Linksys Velop WHW01 Teardown, Slide out the LED module: adım 9, 3 resimden 1. Linksys Velop WHW01 Teardown, Slide out the LED module: adım 9, 3 resimden 2. Linksys Velop WHW01 Teardown, Slide out the LED module: adım 9, 3 resimden 3.
    • Carefully pull the LED module out of the groove its slid into.
    • Be careful with the highly fragile ribbon cable, it is soldered on the LED and main board and does not detach!
  10. Linksys Velop WHW01 Teardown, Remove the antenna bracket: adım 10, 1 resimden 1.
    • Lift off the antenna bracket, being mindful of the LED module.
  11. Linksys Velop WHW01 Teardown, Unclip the bluetooth antenna: adım 11, 1 resimden 1.
    • Unclip the Bluetooth antenna, the same procedure as the WiFi antennas.
  12. Linksys Velop WHW01 Teardown, Remove the plastic bracket: adım 12, 3 resimden 1. Linksys Velop WHW01 Teardown, Remove the plastic bracket: adım 12, 3 resimden 2. Linksys Velop WHW01 Teardown, Remove the plastic bracket: adım 12, 3 resimden 3.
    $5.49
    • Use a Phillips #00 Screwdriver to unscrew the screw holding the rear plastic bracket.
    • Turn the assembly around and lift the bracket off the main board.
  13. Linksys Velop WHW01 Teardown, Remove the front heatsink: adım 13, 3 resimden 1. Linksys Velop WHW01 Teardown, Remove the front heatsink: adım 13, 3 resimden 2. Linksys Velop WHW01 Teardown, Remove the front heatsink: adım 13, 3 resimden 3.
    $5.49
    • Use a Phillips #00 Screwdriver to unscrew the three screws securing the heatsink.
    • After removing the screws you will need to twist it side to side a little bit due to the thermal pad.
  14. Linksys Velop WHW01 Teardown, Remove the back heatsink: adım 14, 1 resimden 1.
    • After removing the upper heatsink, the heatsink on the back of the board can be removed using a similar process to the top heatsink.
    • Only small and gentle side to side movement is needed to release the thermal pads.
Lewis L. Foster
266 İtibar
1 Kılavuz yazıldı
4 Yorum
Very well done! In terms of disassembly, how long did it take to get everything apart?
Jacob Mehnert - Yanıt
definitely no longer than 10 mins, even shorter if you are only going in to access the serial port for flashing a custom firmware
Lewis L. Foster -
Great information, thank you for doing this! Did I see a proprietary antenna connector and no ts9?
Courtney Glenn - Yanıt
Not really clued up on my antennas so not sure
Lewis L. Foster -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 92
Her zaman: 4,096
