Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Linksys WRT54G cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Linksys WRT54G Teardown, Get your Linksys: adım 1, 2 resimden 1. Linksys WRT54G Teardown, Get your Linksys: adım 1, 2 resimden 2.
    • The Linksys WRT54G series is a series of Wi-Fi gateways manufactured by Linksys, a subsidiary of Cisco Systems.
  2. Linksys WRT54G Teardown, Antenna Removal: adım 2, 2 resimden 1. Linksys WRT54G Teardown, Antenna Removal: adım 2, 2 resimden 2.
    • Let's begin with the teardown! First, unscrew the antennas from the back of the router and set them aside.
  3. Linksys WRT54G Teardown, Front Panel Removal: adım 3, 3 resimden 1. Linksys WRT54G Teardown, Front Panel Removal: adım 3, 3 resimden 2. Linksys WRT54G Teardown, Front Panel Removal: adım 3, 3 resimden 3.
    • Lets get into the internals! First, flip the unit over and insert a small flat-head screwdriver in between the warranty sticker and the front panel and gently pry it open.
    • Beware! It may take some effort to pry the panel off. Also, be careful not to damage the motherboard, like I did.
    • This will certainly void your warranty from 2002, in case you wanted to know.
  4. Linksys WRT54G Teardown, Remove Top Panel: adım 4, 3 resimden 1. Linksys WRT54G Teardown, Remove Top Panel: adım 4, 3 resimden 2. Linksys WRT54G Teardown, Remove Top Panel: adım 4, 3 resimden 3.
    • Now, slide the top plastic panel off and put it aside you now have a clear view of the motherboard.
    • Intel TE28F320 Flash Memory
    • Broadcom BCM4712KPB (I think it’s a modem chip)
    • Admtek ADM6996L Ethernet Controller
    • Activity LEDs
    • Issi 42S16400-6T Random Access Memory (unsure how much)
    • An assortment of other chips I couldn't find.
  5. Linksys WRT54G Teardown, Remove Motherboard: adım 5, 3 resimden 1. Linksys WRT54G Teardown, Remove Motherboard: adım 5, 3 resimden 2. Linksys WRT54G Teardown, Remove Motherboard: adım 5, 3 resimden 3.
    • Time to remove the motherboard! Unscrew the single Phillips screw, slide the motherboard and then lift it out.
    • Single Phillips screw
    • Plastic slips holding the motherboard in place.
  6. Linksys WRT54G Teardown, Done!: adım 6, 1 resimden 1.
    • You're done! Thanks for sticking with me for my first teardown!
    • If you want to reassemble this, just do this guide in reverse order! (assuming you didn't break it like I did)
Reed Crosby
4.389 İtibar
1 Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
184 Üyeler
256 adet Kılavuz yazıldı
2 Yorum
Happened to get one of these from goodwill recently and wanted to take it apart to take a look. This was really helpful for doing that, deeply appreciate these teardown posts.
Chris Caldwell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 8,132
