Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Logitech 2-MP Webcam C600 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Logitech 2-MP Webcam C600 Teardown, Teardown: adım 1, 3 resimden 1. Logitech 2-MP Webcam C600 Teardown, Teardown: adım 1, 3 resimden 2. Logitech 2-MP Webcam C600 Teardown, Teardown: adım 1, 3 resimden 3.
  2. Logitech 2-MP Webcam C600 Teardown: adım 2, 3 resimden 1. Logitech 2-MP Webcam C600 Teardown: adım 2, 3 resimden 2. Logitech 2-MP Webcam C600 Teardown: adım 2, 3 resimden 3.
    • Pry off the button mounted on the side
    • Green arrow indicates the location of screw hole
    • Use a #0 Phillips head screwdriver to remove the screw
  3. Logitech 2-MP Webcam C600 Teardown: adım 3, 3 resimden 1. Logitech 2-MP Webcam C600 Teardown: adım 3, 3 resimden 2. Logitech 2-MP Webcam C600 Teardown: adım 3, 3 resimden 3.
    • Remove the screw indicated by the green arrows
    • The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment
  4. Logitech 2-MP Webcam C600 Teardown: adım 4, 3 resimden 1. Logitech 2-MP Webcam C600 Teardown: adım 4, 3 resimden 2. Logitech 2-MP Webcam C600 Teardown: adım 4, 3 resimden 3.
    • The screws indicated by the blue arrows hold the lens module in place
    • The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass.
  5. Logitech 2-MP Webcam C600 Teardown: adım 5, 2 resimden 1. Logitech 2-MP Webcam C600 Teardown: adım 5, 2 resimden 2.
    • Attached to the white plastic is the privacy shade position sensor.
    • The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
    • The lens is threaded M10x0.5, and testing seems to indicate that the sensor is a CCD with global shutter.
I Heart Robotics
210 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 27,510
