Ana içeriğe geç
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Bu Teardown'da Kullanılan Aletler
Giriş
How to take apart the M6013 Capacitor Meter
  1. Remove the circled screw Remove battery case and batteries
    • Remove the circled screw
    • Remove battery case and batteries
  2. Remove circled screws Pull case apart Watch out for buttons, they will fall out easily.
    • Remove circled screws
    • Pull case apart
    • Watch out for buttons, they will fall out easily.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  4. Remove circled screws Be careful when removing the circuit board, the battery cable is still connected. Unsolder the square locations either on the circuit board or the case to fully remove the circuit board
    • Be careful when removing the circuit board, the battery cable is still connected.
    • Unsolder the square locations either on the circuit board or the case to fully remove the circuit board
  5. Location of microprocessor Location of microprocessor
    • Location of microprocessor
  6. Remove the cable connector Remove Display
    • Remove the cable connector
    • Remove Display
Ted Hsueh
170 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G56
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Add some specs on start and foto of the unit ....
Mateusz Bonkowski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 362
