Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Dual USB Connector cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: adım 1, 1 resimden 1.
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  2. MSI Dual USB Port Bracket Teardown: adım 3, 1 resimden 1.
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
415 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Why does it need its owe usb header just for the LED's.
Rick Acker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 7,580
