Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Mac Pro 2009-2012 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Mac Pro 2009-2012 Teardown, Open the Case: adım 1, 3 resimden 1. Mac Pro 2009-2012 Teardown, Open the Case: adım 1, 3 resimden 2. Mac Pro 2009-2012 Teardown, Open the Case: adım 1, 3 resimden 3.
    • To open the Mac Pro, you'll have to lift the clip on the back of the case
    • Leave the clip open during the entire disassembly!
  2. Mac Pro 2009-2012 Teardown, Remove the side panel: adım 2, 2 resimden 1. Mac Pro 2009-2012 Teardown, Remove the side panel: adım 2, 2 resimden 2.
    • Lift the flap to put it in the unlocked position, the panel should separate from the box without forcing.
  3. Mac Pro 2009-2012 Teardown, Remove the hard drives: adım 3, 2 resimden 1. Mac Pro 2009-2012 Teardown, Remove the hard drives: adım 3, 2 resimden 2.
    • Then to remove the hard drives, pull them towards you with a bit of force.
  4. Mac Pro 2009-2012 Teardown, Remove the DVD drives: adım 4, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the DVD drives: adım 4, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the DVD drives: adım 4, 3 resimden 3.
    • Pull the DVD drives towards you, just like the hard drives.
  5. Mac Pro 2009-2012 Teardown, Remove the CPU board: adım 5, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the CPU board: adım 5, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the CPU board: adım 5, 3 resimden 3.
    • Press both latches to unlock the bracket and then pull it towards you.
    • You shouldn't need to apply much force.
  6. Mac Pro 2009-2012 Teardown, Disconnect the GPU: adım 6, 2 resimden 1. Mac Pro 2009-2012 Teardown, Disconnect the GPU: adım 6, 2 resimden 2.
    • Remove the 6 or 8 pin connector from your graphics card.
    • This step is optional, it will depend on the graphics card of your Mac Pro
  7. Mac Pro 2009-2012 Teardown, Disconnect the GPU power supply ( Optional ): adım 7, 3 resimden 1. Mac Pro 2009-2012 Teardown, Disconnect the GPU power supply ( Optional ): adım 7, 3 resimden 2. Mac Pro 2009-2012 Teardown, Disconnect the GPU power supply ( Optional ): adım 7, 3 resimden 3.
    • On the power supply there is a button, press it to move the power supply to the left (see picture)
    • Then pull the graphics card towards you to take it out of the box
    • This step is optional depending on the GPU of your Mac Pro
  8. Mac Pro 2009-2012 Teardown, Disconnect GPU support ( optional): adım 8, 2 resimden 1. Mac Pro 2009-2012 Teardown, Disconnect GPU support ( optional): adım 8, 2 resimden 2.
    • Disconnect the PCI-e cables from the motherboard
    • This step is optional depending on your Mac Pro
  9. Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: adım 9, 3 resimden 1. Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: adım 9, 3 resimden 2. Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: adım 9, 3 resimden 3.
    • With a screwdriver unscrew the two screws that hold the fan bracket to the board
    • Pull the fan towards you
  10. Mac Pro 2009-2012 Teardown, Disconnect the SATA Cables: adım 10, 2 resimden 1. Mac Pro 2009-2012 Teardown, Disconnect the SATA Cables: adım 10, 2 resimden 2.
    • Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
  11. Mac Pro 2009-2012 Teardown, Unscrew CPU support: adım 11, 3 resimden 1. Mac Pro 2009-2012 Teardown, Unscrew CPU support: adım 11, 3 resimden 2. Mac Pro 2009-2012 Teardown, Unscrew CPU support: adım 11, 3 resimden 3.
    • With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
    • With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
  12. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: adım 12, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: adım 12, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: adım 12, 3 resimden 3.
    • Remove the clip at the top of the fan
    • Pull on the top of the fan a bit.
  13. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: adım 13, 2 resimden 1. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: adım 13, 2 resimden 2.
    • Similar to the top remove the clip at the bottom and pull out the fan.
  14. Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: adım 14, 3 resimden 1. Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: adım 14, 3 resimden 2. Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: adım 14, 3 resimden 3.
    • Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
    • Do not forget this step or you risk damaging your connectors on the motherboard and make unusable fans and speaker!
  15. Mac Pro 2009-2012 Teardown, Remove the CPU Support: adım 15, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the CPU Support: adım 15, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the CPU Support: adım 15, 3 resimden 3.
    • Pull the CPU support towards you
    • Do not use force during this step,It it does not come out easily ensure the fans are not blocking the exit.
  16. Mac Pro 2009-2012 Teardown, Remove the expansion card connector: adım 16, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the expansion card connector: adım 16, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the expansion card connector: adım 16, 3 resimden 3.
    • Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
    • Attention, it is necessary to remove the cable carefully so as not to bend the pins which are in the connector of the motherboard!
  17. Mac Pro 2009-2012 Teardown, Remove the expansion card: adım 17, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the expansion card: adım 17, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the expansion card: adım 17, 3 resimden 3.
    • Unscrew the 6 screws that hold the card in place.
    • Be careful to unplug the power cable on the card !!
  18. Mac Pro 2009-2012 Teardown, Remove the cover: adım 18, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the cover: adım 18, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the cover: adım 18, 3 resimden 3.
    • unscrew the two screws and remove the cover
  19. Mac Pro 2009-2012 Teardown, Unplug the power supply: adım 19, 3 resimden 1. Mac Pro 2009-2012 Teardown, Unplug the power supply: adım 19, 3 resimden 2. Mac Pro 2009-2012 Teardown, Unplug the power supply: adım 19, 3 resimden 3.
    • Push on both knobs to remove the power connector
    • Do not use force, if you are struggling ensure you are squeezing the clips adequately.
  20. Mac Pro 2009-2012 Teardown, Separate the power supply: adım 20, 2 resimden 1. Mac Pro 2009-2012 Teardown, Separate the power supply: adım 20, 2 resimden 2.
    • Unscrew the 4 screws that hold in the power supply
  21. Mac Pro 2009-2012 Teardown, Remove the power supply: adım 21, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the power supply: adım 21, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the power supply: adım 21, 3 resimden 3.
    • Pull the power supply towards you.
    • Be sure to pull the connector forward and watch the cables
  22. Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: adım 22, 3 resimden 1. Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: adım 22, 3 resimden 2. Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: adım 22, 3 resimden 3.
    • Unclip the bluetooth antenna
  23. Mac Pro 2009-2012 Teardown, Remove the mother board: adım 23, 3 resimden 1. Mac Pro 2009-2012 Teardown, Remove the mother board: adım 23, 3 resimden 2. Mac Pro 2009-2012 Teardown, Remove the mother board: adım 23, 3 resimden 3.
    • Unscrew the 10 screws holding in the motherboard
  24. Mac Pro 2009-2012 Teardown, Change the case: adım 24, 1 resimden 1.
    • Follow the steps in reverse to resemble.
Ben Capehart
9.428 İtibar
19 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 69
Son 30 gün: 354
Her zaman: 5,327
