Bu Teardown'da Kullanılan Aletler
Öne Çıkan Belge
Shut down the computer and disconnect the power cord and any other cables connected to the computer
Place the computer face down
Slide both battery latches away and lift the battery out
Remove the three screws from the memory door
Remove the door as shown
Remove the memory cards by carefully spreading the tabs away from the card
Pull the card straight back and out
Remove the six screws on the bottom and the two in the battery bay
Remove the four screws from the side and two on the back
Open the display slightly past 90 degrees and use a spudger to loosen the top case
Slowly lift the top case until you can see the ribbon cable, carefully unplug then lift the top case off
