Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Mastercraft 17FY2-MC Cordless Drill cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the screws from the casing: adım 1, 1 resimden 1.
    • Use a Phillips head screwdriver to remove the 6 screws from the casing
  2. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the battery: adım 2, 3 resimden 1. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the battery: adım 2, 3 resimden 2. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the battery: adım 2, 3 resimden 3.
    • First remove the two yellow twist-on connectors from the bottom of the handle, then bend the wires away from each other to prevent accidental reconnection
    • This disconnects the negative side of the battery, and removes the danger of touching other parts of the drill while the battery is connected
    • Then remove the two yellow twist-on connectors from the top of the drill, and remove the entire battery pack
  3. Mastercraft 17FY2-MC Cordless Drill Teardown, The battery pack: adım 3, 1 resimden 1.
    • The drill uses a battery pack consisting of four NiCd cells each with a nominal voltage of 1.2V. This gives a total pack voltage of 4.8V when all batteries are connected in series.
  4. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove motor assembly from casing: adım 4, 2 resimden 1. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove motor assembly from casing: adım 4, 2 resimden 2.
    • Slide the charging port, trigger switch, and direction switch out of their slots in the casing. Then remove the entire motor assembly from the casing
  5. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the drill mechanism from the motor: adım 5, 3 resimden 1. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the drill mechanism from the motor: adım 5, 3 resimden 2. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the drill mechanism from the motor: adım 5, 3 resimden 3.
    • Remove three screws on the motor with a Phillips head screwdriver to disconnect the drill mechanism from the motor
    • The DC motor (second image) spins a shaft connected to a small gear.
    • The drill mechanism (third image) uses a set of gears to provide more torque to the drill head.
  6. Mastercraft 17FY2-MC Cordless Drill Teardown, Motor control electronics: adım 6, 3 resimden 1. Mastercraft 17FY2-MC Cordless Drill Teardown, Motor control electronics: adım 6, 3 resimden 2. Mastercraft 17FY2-MC Cordless Drill Teardown, Motor control electronics: adım 6, 3 resimden 3.
    • The three parts of the controlling electronics are (from left to right in the first image): the charging port, the trigger mechanism, and the direction switch.
    • The charging port (second image) charges the battery when a DC power supply is inserted into the connector. The port also lights up a red LED while charging.
    • The trigger switch controls the speed of the motor by connecting more of the batteries as the trigger is depressed further.
    • The direction switch controls the polarity of the voltage connected to the motor, which spins the motor either clockwise or counterclockwise.
  7. Mastercraft 17FY2-MC Cordless Drill Teardown, Parts overview: adım 7, 1 resimden 1.
    • This concludes the teardown of the Mastercraft 17FY2-MC Cordless Drill
Ian Lang
101 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 632
