Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Mouse cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Mechanical Mouse Teardown, Mechanical Mouse Teardown: adım 1, 3 resimden 1. Mechanical Mouse Teardown, Mechanical Mouse Teardown: adım 1, 3 resimden 2. Mechanical Mouse Teardown, Mechanical Mouse Teardown: adım 1, 3 resimden 3.
    • Rotate mouse over and locate Trackball cover
    • Using index fingers and thumb, rotate counter-clockwise
  2. Mechanical Mouse Teardown: adım 2, 3 resimden 1. Mechanical Mouse Teardown: adım 2, 3 resimden 2. Mechanical Mouse Teardown: adım 2, 3 resimden 3.
    • After the Trackball cover has been rotated, pry the lid off using fingernails.
    • Remove Trackball cover and place to the side.
    • Angle mouse to eject Trackball from the casing.
  3. Mechanical Mouse Teardown: adım 3, 3 resimden 1. Mechanical Mouse Teardown: adım 3, 3 resimden 2. Mechanical Mouse Teardown: adım 3, 3 resimden 3.
    • Using a Phillips head screwdriver, locate screw hole and unscrew the screw inside.
    • Lift the two cases apart and place screw to the side.
  4. Mechanical Mouse Teardown: adım 4, 3 resimden 1. Mechanical Mouse Teardown: adım 4, 3 resimden 2. Mechanical Mouse Teardown: adım 4, 3 resimden 3.
    • Remove the wire from the plastic casing near the top of the mouse.
    • Lift up to remove the PCB which is attached to the mouse.
    • Place case to the side.
  5. Mechanical Mouse Teardown: adım 5, 3 resimden 1. Mechanical Mouse Teardown: adım 5, 3 resimden 2. Mechanical Mouse Teardown: adım 5, 3 resimden 3.
    • Locate where the wire is connected to the PCB via the white connection.
    • Pry the connections apart and place the cable to the side.
Kevin Gingrich
180 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G28
4 Üyeler
15 adet Kılavuz yazıldı
2 Comments
Wow! Someone really worked hard on this guide. Kudos sir.
Tushar Varshney - Yanıt
Yes sir I won't know everything about the machine
mubarak wad gab tagel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 70
Her zaman: 4,975
