Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Desktop PC cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Microdigital TK 85 Teardown, The TK 85 case and connectors: adım 1, 3 resimden 1. Microdigital TK 85 Teardown, The TK 85 case and connectors: adım 1, 3 resimden 2. Microdigital TK 85 Teardown, The TK 85 case and connectors: adım 1, 3 resimden 3.
    • 9V DC = Nomo P2 power supply
    • Expansão = Expansion connector 2x23 edge pins.
    • Joystick = Joystick connector DIN-6-07M.
    • Mic = audio output for a datacorder.
    • Ear = Audio input for a datacorder.
    • Video = RF chanel 3 VHF output.
  2. Microdigital TK 85 Teardown, Inside the TK85: adım 2, 3 resimden 1. Microdigital TK 85 Teardown, Inside the TK85: adım 2, 3 resimden 2. Microdigital TK 85 Teardown, Inside the TK85: adım 2, 3 resimden 3.
    • Open it carefully because of the 2 keyboard flat cables.
    • Those flat cables are very problematic
  3. Microdigital TK 85 Teardown, Keyboard removed: adım 3, 2 resimden 1. Microdigital TK 85 Teardown, Keyboard removed: adım 3, 2 resimden 2.
    • The upper part of the case is the keyboard, but the keyboard itself is not removable.
    • The lower part of the case is just a plastic part.
  4. Microdigital TK 85 Teardown, The circuit board: adım 4, 2 resimden 1. Microdigital TK 85 Teardown, The circuit board: adım 4, 2 resimden 2.
    • The circuit board is a very compact circuit board with dual layer traks.
  5. Microdigital TK 85 Teardown, Rom and Ram: adım 5, 2 resimden 1. Microdigital TK 85 Teardown, Rom and Ram: adım 5, 2 resimden 2.
    • MM2716Q-5 => 16Kb Eprom
    • 52164KSF/N => 64kb Rom ? It is a custom Microdigital Rom compatible with the NMC2764.
    • MCM4116BC-15 => 8 x 16,348 bits Ram = 16Kb Ram
  6. Microdigital TK 85 Teardown, The RF generator: adım 6, 3 resimden 1. Microdigital TK 85 Teardown, The RF generator: adım 6, 3 resimden 2. Microdigital TK 85 Teardown, The RF generator: adım 6, 3 resimden 3.
    • Just a RF Chanel 3 VHF modulator.
  7. Microdigital TK 85 Teardown, Microchips identification: adım 7, 2 resimden 1. Microdigital TK 85 Teardown, Microchips identification: adım 7, 2 resimden 2.
    • Microprocessor
    • Rom
    • Eprom
    • Ram
    • Oscilator 555. Works as an PWM 5 Volt power supply to the micropocessor.
    • Spare space for an audio integrated circuit. It was never implemented in producion in this model.
    • Voltage regulator 7805
    • Frequency divider = 6,5Mhz used for video and 3,25Mhz used for actual clock.
Vinicius Rodrigues Bellini
1.046 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 21
Her zaman: 1,080
