Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Microsoft Surface Studio Gen 1 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Microsoft Surface Studio Teardown, Microsoft Surface Studio Teardown: adım 1, 2 resimden 1. Microsoft Surface Studio Teardown, Microsoft Surface Studio Teardown: adım 1, 2 resimden 2.
    • It's no stocking, but we're thinking this machine is still stuffed with goodies:
    • 28-inch adjustable PixelSense Display with 4500 x 3000 resolution (192 DPI)—supporting sRGB, DCI-P3, and Vivid color profiles, plus 10-point multi-touch
    • 6th-Generation Intel Core i5 or i7 CPU with 8 GB, 16 GB, and 32 GB RAM configuration options
    • NVIDIA GeForce GTX 965M GPU (paired with 2 GB GDDR5) or GTX 980M (paired with 4 GB GDDR5)
    • 1 TB and 2 TB hybrid storage options
    • 802.11ac Wi-Fi / Bluetooth 4.0 / Xbox Wireless built-in
    • Supports Surface Pen and Surface Dial
    • At 21 lbs, it takes some effort to spin this thing around—but it pops down to 20º with the push of a finger.
    • The angle is an intentional one—not only is it a common angle for artists and animators, but you can't set a coffee down on this slope, minimizing spills.
  2. Microsoft Surface Studio Teardown: adım 3, 3 resimden 1. Microsoft Surface Studio Teardown: adım 3, 3 resimden 2. Microsoft Surface Studio Teardown: adım 3, 3 resimden 3.
    • The display is this PC's party piece, but we aren't throwing any confetti just yet. First, we'll take a look at what kind of portage it's packing. From left to right:
    • Four USB 3.0 ports
    • Gigabit Ethernet jack and power inlet
    • Mini DisplayPort
    • SD card slot and 3.5 mm audio jack
    • Meanwhile, along the bottom edge of the display, we note a wide strip of speaker grille—we'll soon see how functional those dots are.
    • Oh, and a whole sensor array worthy of the Federation, including: facial recognition sign-in camera with IR projector (probably), 5 MP camera, and two microphones.
  3. Microsoft Surface Studio Teardown: adım 4, 3 resimden 1. Microsoft Surface Studio Teardown: adım 4, 3 resimden 2. Microsoft Surface Studio Teardown: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Satın Al
    • Enough of the outside, we're here to see what's on the inside. We tip the Studio onto its back and inspect the base, hoping to find our way in.
    • A strip of air vents borders the entire bottom panel, and at each corner we find a round rubber foot—concealing a Torx screw.
    • The two on the front corners were of the extra-long variety. As manufacturers continue the fight against visible screws, we're okay with this solution—it's certainly better than gluing the entire thing shut.
    • Screws jettisoned, the heavy bottom cover still holds on by way of several clips. So, we apply a little suction power to help yank it free.
    • With that, we're inside the Actors Surface Studio.
    In the two articles I've read here on pulling apart the Surface Studio, I found it interesting that in both cases, people decided to tear it down with the display floating in the air, having the power plug facing the bench.
    I placed the surface display completely flat on the table and took it apart that way. This enabled testing of the fans [and relying on the thermal shutdown to protect itself if it needed to], which one really cannot do with the plug on the desk. I also think this position is better for the display and puts no undue torque on it.
    Turns out, if you do that, then the fans have enough cord to lie flat on the desk as you blow them clean [and find out if one, like mine, needs to be replaced]. In addition, when the midframe comes off, the speaker is pretty nice and stable on the bench, and there is little to no chance of accidentally damaging that baby.
    So the way I did it is how I recommended it, regardless of the articles here.
    Eric Snyder - Yanıt
    When you pull off the feet, best to use the tweeters as shown here. You need to get in and under the foot in order to pull it off, because it is glued with some sticky nasty stuff like stronger sticky notes. But be careful, not only to not scratch your base, but also to not bend the very tiny ends of the tweezer.
    I recommend highly the iFixit Pro Toolkit. Your old surface is worth it, and your new gadgets will also need to be torn apart eventually anyway, so it is a long-term investment.
    Eric Snyder - Yanıt
  4. Microsoft Surface Studio Teardown: adım 5, 2 resimden 1. Microsoft Surface Studio Teardown: adım 5, 2 resimden 2.
    • Pulling the back cover off reveals a myriad of components ...
    • ... most of which we can't actually access just yet.
    • There's a strict and slightly perilous order of operations here. First out are two fans, but they remain anchored by wires with hidden leads. That midframe will have to come out before we can proceed further.
    • As we lift away the midframe, it brings an attached speaker out with it, along with a third wire tether to the motherboard.
    • It's a teardown, not a space walk! Cut us some slack here, Houston Redmond.
  5. Microsoft Surface Studio Teardown: adım 6, 3 resimden 1. Microsoft Surface Studio Teardown: adım 6, 3 resimden 2. Microsoft Surface Studio Teardown: adım 6, 3 resimden 3.
    • With a bit more finagling, we extract the two brushless, Delta-made exhaust fans.
    • They're sized quite differently. Is there a dedicated fan for the CPU, and a second for the GPU? Because that would be cool.
    • With the speaker wire disconnected, the midframe finally falls away, with the speaker still attached.
    • Notably, the speaker itself is anchored and vibration-proofed by way of some (very Apple-esque) rubber screw gaskets.
    • Finally, we have access to some guts—this Studio is chock-full of 'em. But we need to delve a little deeper to see if it has the glory.
  6. Microsoft Surface Studio Teardown: adım 7, 3 resimden 1. Microsoft Surface Studio Teardown: adım 7, 3 resimden 2. Microsoft Surface Studio Teardown: adım 7, 3 resimden 3.
    • Dig in! We start with the high-powered half of this machine's hybrid storage: a standard, removable, 64 GB SanDisk Z400s M.2 SSD. And on board we find:
    • SanDisk 05466 032G 32 GB NAND flash storage module (x2 for a total of 64 GB)
    • Silicon Motion SM2246XT SATA III 6 Gb/s DRAM-less SSD Controller
    • Texas Instruments power management
    • Amusingly, someone must have decided it'd be better to slap down two 32 GB chips (perhaps leaving room for the 128 GB models), rather than four 16 GB chips—hence this pair of empty solder pads.
    • If you happen to have a couple flash storage modules and a hot air rework station lying around, the SSD controller should happily take up to four NAND flash devices.
    Very good condition
    Benjamin Rodriguez - Yanıt
  7. Microsoft Surface Studio Teardown: adım 8, 3 resimden 1. Microsoft Surface Studio Teardown: adım 8, 3 resimden 2. Microsoft Surface Studio Teardown: adım 8, 3 resimden 3.
    • Next, we mine for copper, extracting the shiny heat sink. A tall standoff spacer, reminiscent of those found in 27" iMacs, holds this beast in place.
    • The heat sink offers quite a bit of cooling power in a tiny package:
    • Heat pipes coming off of each processor (CPU and GPU) flow out to exhaust radiators, each of which has a dedicated fan to blow all that hot air out of the system.
    • The CPU fan, being positioned not-quite over the radiator, blows down a plastic channel.
    • The GPU fan is the larger of the two, and its radiator gets a bonus heat pipe that runs from both the CPU and GPU, which may allow for some thermal load leveling.
    • It looks like Microsoft is getting quite a bit cooler than its late 2000s reputation, if you know what we mean.
  8. Microsoft Surface Studio Teardown: adım 9, 2 resimden 1. Microsoft Surface Studio Teardown: adım 9, 2 resimden 2.
    • We're pleased to report that there's a standard SATA hard drive connector in here—and attached to it, a standard SATA hard drive.
    • It took a little work to get here, but it seems there is indeed a complete storage upgrade path for your $3,000-4,000 desktop machine. As there should be.
    • It's nothing fancy, but here are the specs on this 2.5" laptop hard drive:
    • Seagate Spinpoint M8 ST1000LM024 5400 RPM, 1 Terabyte, SATA 3.0 Gb/s hard drive
    • Yep, the spec sheet says this is a SATA II drive. Surprising? A bit. Lame? Kind of. Fixable? Probably—but someone will need to swap in a SATA III drive and run some read/write tests to verify.
    请问主板上的接口是什么类型的?看起来不像是标准的sata接口
    end2 - Yanıt
  9. Microsoft Surface Studio Teardown: adım 10, 3 resimden 1. Microsoft Surface Studio Teardown: adım 10, 3 resimden 2. Microsoft Surface Studio Teardown: adım 10, 3 resimden 3.
    • Not only does the Studio have an SD card slot, but it's on its own modular board! Other barnacles include:
    • Realtek RTS5314 SD card reader controller
    • Macronix MX25L1006E 1 Mb CMOS serial flash
    • ON Semiconductor FSA644UCX 1.5 Gbps SPDT 4-data lane switch
  10. Microsoft Surface Studio Teardown: adım 11, 3 resimden 1. Microsoft Surface Studio Teardown: adım 11, 3 resimden 2. Microsoft Surface Studio Teardown: adım 11, 3 resimden 3.
    • From here we're able to pull out the power supply, a custom Lite-On unit with a dual-voltage (100-240 V) rating.
    • The power supply features its own small, internal cooling fan. Our button fingers twitch involuntarily; we're having Xbox One flashbacks.
    • Overall impressions: it's a power supply. It's a beefy, well-insulated power supply. Are you happy? Alright then. Moving on.
    • IC Identification:
    • NXP Semiconductor TEA1995T dual synchronous rectifier controller
    • STMicroelectronics STTS751-0DP3F digital temperature sensor
    LOL, it is not dual-voltage rated. :D
    It is fom 100V to 240V range rated.
    preziremprokletigugl - Yanıt
  11. Microsoft Surface Studio Teardown: adım 12, 2 resimden 1. Microsoft Surface Studio Teardown: adım 12, 2 resimden 2.
    • We're so close to the motherboard we can almost taste it. Best guess: it will taste like fiberglass and copper.
    • Meanwhile, one last component stands in our way: this little headphone jack.
    • We're not sure if the headphone jack's days are numbered, but we're pleased to see it make an appearance here—even if it's somewhat inconveniently located allllllll the way in the back, where you can plug in if you brought a dental inspection mirror.
    • More importantly, this little guy is completely modular—so you can swap it out with a little patience, should the need arise.
    • With that, the motherboard is free. Huzzah! Let's inspect those chips.
  12. Microsoft Surface Studio Teardown: adım 13, 2 resimden 1. Microsoft Surface Studio Teardown: adım 13, 2 resimden 2.
    • Top side, we have the following ICs:
    • Intel Core i5-6440HQ Processor (6M Cache, up to 3.50 GHz)
    • Eight Samsung K4A4G085WE-BCPB 512 MB DDR4 RAM (4 GB on this side and another 4 GB on the reverse)
    • Nvidia GeForce GTX 965M GPU
    • Intel GL82CM236 Platform Hub Controller
    • ON Semiconductor NCP81205 3+3+1 Phase Controller
    • Infineon SLB 9665 TT 2.0 TPM (as seen in the Surface Book) and Infineon 0812ND HBE613 (x14)
    • Winbond W25Q128FV 128 M Serial Bit Flash Memory
    The GL82CM236 is in interesting PCH choice here - it is a Xeon-capable PCH, supporting the likes of Xeon E3-1575Mv5 (up to 3.9GHz!) and ECC memory. Did you folks see any indications of a ninth and an eighteenth memory chip on the motherboard? If so, there may just be a possibility of a workstation grade Studio, boasting Xeon E3-1500Mv5 processor, ECC memory and a Maxwell-based Quadro GPU. That machine would probably also comes with Windows 10 Enterprise and a 10-year warranty.
    xcvista - Yanıt
  13. Microsoft Surface Studio Teardown: adım 14, 2 resimden 1. Microsoft Surface Studio Teardown: adım 14, 2 resimden 2.
    • Side two:
    • Four SK Hynix H5GC4H24AJR 512 MB GDDR5 SDRAM (for a total of 2 GB)
    • Eight additional Samsung K4A4G085WE-BCPB 512 MB DDR4 (for a grand total of 8 GB)
    • Winbond W25X40CL serial flash memory
    • ITE IT8527VG I/O controller
    • Realtek ALC3269 audio codec
    • Intel I219-LM gigabit ethernet controller
    • Texas Instruments LM358A dual operational amplifier
  14. Microsoft Surface Studio Teardown: adım 15, 2 resimden 1. Microsoft Surface Studio Teardown: adım 15, 2 resimden 2.
    • IC Identifications, continued:
    • STMicroelectronics STTS751 digital temperature sensor
    • Goodix (formerly NXP Semiconductor) TFA9890A class-D audio amplifier
    • Texas Instruments INA3221 13-bit current/voltage monitor
    • Richtek RT8813A multiphase PWM controller
    • Richtek RT6575D 2-ch. synchronous DC-DC step-down controller
    • Richtek RT8171C single-phase controller for Intel CPU
    • Richtek RT8231B DDR memory power supply
  15. Microsoft Surface Studio Teardown: adım 16, 2 resimden 1. Microsoft Surface Studio Teardown: adım 16, 2 resimden 2.
    • As promised, it's time to return to that huge 28" glass display. Gulp.
    • Unsure what kind of adhesive lies in wait (nasty Surface adhesive? Nice iMac adhesive?), we throw down a pair of iOpeners to soften it up.
    • Many swipes of the iMac opening tool later, and we're ready to call this glue the in-between. It's not the overkill tar we saw in the Surface Pro, but it's also not slice-it-down-the-middle clean iMac adhesive. It's in between. A bit of a struggle, but not impossible.
    • ... But after that bit of struggle, lifting the glass is fruitless—it won't budge. Looks like we're missing some fasteners in the center of the LCD. Where might those be?
  16. Microsoft Surface Studio Teardown: adım 17, 3 resimden 1. Microsoft Surface Studio Teardown: adım 17, 3 resimden 2. Microsoft Surface Studio Teardown: adım 17, 3 resimden 3.
    • We temporarily shift our attention to a more screw-y, less glue-y portion of this desktop, in the hopes that we will have more luck in removing it.
    • Lacking a specialized tool for the job, we hand-beast the hinge casing off the back of the display. A slew of tiny clips keep it tightly stuck, with no adhesive or screws.
    • Underneath lurks a pair of antennas, significantly-more-than-a-pair of springs, and loads of screws.
    • The multiple spring mechanisms allow the monitor to transition from vertical to nearly-horizontal with just a light touch.
    • Removing the screws securing the hinge to the display is like playing Russian Roulette: some are spring-loaded while others are not. We test our odds, and manage to select all of the correct screws for removal, detaching the base without a springtastic explosion.
    I'd prefer the "safe" screws were marked, and perhaps the spring-loaded ones marked in red :)
    hhamran - Yanıt
    Hello, i am trying to find out if it would be possible to modify the stand to allow the screen go fully horizontal ?
    If some kind of adjustment would allow that by losing the vertical end.
    Thanks in advance
    elpachato - Yanıt
  17. Microsoft Surface Studio Teardown: adım 18, 2 resimden 1. Microsoft Surface Studio Teardown: adım 18, 2 resimden 2.
    • We took the long way there, but it looks like a simple display replacement is one of the easiest jobs on the Studio. Good news for any folks prone to being a little hamfisted with their Surface Dial.
    • With the case emptied and display removed, this is still a hefty piece of hardware—clearly the crown jewel of Microsoft's burgeoning engineering prowess.
    • The top bar features a couple of tightly-wound springs and a calibration screw in the center, along with the termination of four display interconnect cables that run inside of the hinges and press onto the back of the display.
    • Inside the foot, the other end of the arms are each tensioned by a pair of extension springs, similar to what you'd find in a garage door.
  18. Microsoft Surface Studio Teardown: adım 19, 3 resimden 1. Microsoft Surface Studio Teardown: adım 19, 3 resimden 2. Microsoft Surface Studio Teardown: adım 19, 3 resimden 3.
    • With the hinge section removed, the display separates cleanly from its housing.
    • Stuck to the inside of the housing is an unusual, asymmetrical set of metal butterfly wings—probably serving as stiffeners and/or counterweights for the enormous pane of glass out front.
    • The back bit hosts a button board, plus two speakers—and way more grille holes than are strictly "holes."
    • This has been a bit of a trend lately.
    Could the “not-really holes” have some "function” in terms of resonating sound or something? (I’m guessing unlikely) Though if the speaker is only right underneath the holes that really *are* holes - it’s hard to thing how any vibration would *get* to the rest of the case.
    jimwitte - Yanıt
  19. Microsoft Surface Studio Teardown: adım 20, 3 resimden 1. Microsoft Surface Studio Teardown: adım 20, 3 resimden 2. Microsoft Surface Studio Teardown: adım 20, 3 resimden 3.
    • Hiding behind the display we find the other half of the motherboard. Seriously, there's way more silicon hiding in this unit than in the base. Highlights include:
    • Monolithic Power Systems MP3387LLED driving, step-up converter (x4)
    • Microsoft X904169 05 CL1631 T518907.1 (x6) likely touchscreen controller
    • Microsoft X904163 01 CL1634 4C39290-01 (x2) likely touchscreen controller
    • Macronix MX25U1635F serial NOR flash (x2)
    • Atmel ATSAMS70N21 32-bit ARM Cortex-M7 processor
    • Novatech NT96131QG-46 likely camera controller
    • Winbond W25X20CL 2 Mb Serial NOR Flash Memory (x2)
    is that display made by samsung?
    shawn khang - Yanıt
  20. Microsoft Surface Studio Teardown: adım 21, 2 resimden 1. Microsoft Surface Studio Teardown: adım 21, 2 resimden 2.
    • IC Identification, continued:
    • Unknown QIC1832-B98B ? programmable gamma buffer (likely)
    • STMicroelectronics STTS751-1DP3F digital temperature sensor
    • Richtek RT9059GQW 3 A LDO regulator
    • Texas Instruments TLV3011 comparator w/ voltage reference
    • Monolithic Power Systems NB671GQ6 A synchronous step-down converter
    • Monolithic Power Systems DC-DC converter
    • Texas Instruments SN74LVC1G3157 SPDT analog switch
  21. Microsoft Surface Studio Teardown: adım 22, 3 resimden 1. Microsoft Surface Studio Teardown: adım 22, 3 resimden 2. Microsoft Surface Studio Teardown: adım 22, 3 resimden 3.
    • And the mid/lowlights:
    • Genesys Logic GL3520 USB 3.1 hub controller
    • NXP TFA9890A (x2) high efficiency class-D audio amplifier
    • Marvell 88W8897 WLAN + BT4.0 + NFC Combo Chip (as seen in past Surface devices)
    • Mediatek MT7600UAN (likely integrated Wi-Fi SoC, as seen in the Xbox One Wireless Receiver)
    • Silicon Mitus SM4142A display power management
    • MegaChips F216 timing controller (likely)
    • Last off the display is the sensor bar with microphones, IR projector and camera combination that powers Windows Hello, along with the built-in 5 MP webcam.
  22. Microsoft Surface Studio Teardown: adım 23, 2 resimden 1. Microsoft Surface Studio Teardown: adım 23, 2 resimden 2.
    • MaxLinear (formerly Exar) iML2811 voltage reference buffer
    • Macronix MX25L512ZUI-12G 512 Kb serial NOR flash memory
    • Rohm BR24T16-W 16 Kb serial EEPROM memory
    • STMicroelectronics M24C32-W 32 Kb serial EEPROM memory (likely)
    • Maxim Integrated MAX17112 LCD step-up DC-DC converter
    • Texas Instruments TPS3808G12 current supervisor
    • Monolithic Power Systems NB671LBGQ and NB671GQ DC-DC converter
  23. Microsoft Surface Studio Teardown: adım 24, 1 resimden 1.
    • We dug way below the surface of this Studio, and here are all the bits we found! Well. Mostly.
  24. Son Düşünceler
    • The base is easy to open and home to several modular components—including the standard SATA hard drive and M.2 SSD—that can be replaced without disassembling the display.
    • The entire display assembly can be replaced as a piece, without dismantling the display or the base.
    • The RAM, CPU, and GPU are soldered to the board and cannot be upgraded. You may want to think twice about that 8 GB configuration.
    • A few components embedded in the display (buttons, front sensors, and speakers) will be difficult to replace if they fail.
    Onarılabilirlik Puanı
    5
    Onarılabilirlik 10 üzerinden 5
    (10 en kolay onarılabileni)
Evan Noronha
223.409 İtibar
168 adet Kılavuz yazıldı
48 Yorum
Wow, iFixit must really be mad at Apple to give this Microsoft product a 5, even after complaining about the hidden fan wires and having to disassemble half the base to get to an antique hard drive. The cop out is replacing the entire display assembly.
plink53 - Yanıt
Both the iMac 5k and Surface Studio have a repairability of 5/10. Looks like they have the same build qualities with both cop outs being the %#*@ display assembly.
Anthony -
I thought the same thing
tjarkoslomski -
The midframe-over-connector design does add to the complexity of basic repairs, but we felt that the lack of adhesive and modular components in the base more than made up for this pesky design feature.
Regarding "antique" hardware: the quality/speed of the hard drive does not factor into the repairability score—we're mainly concerned with how accessible those components are. It would have been nice to find a high-speed SATA III drive lurking underneath, but the fact that this drive can be upgraded/replaced without any destructive disassembly earns major points in our book (although if it was more easily accessible the Studio would have scored higher on our repairability scale).
Evan Noronha -
I think iFixit must be mad at Microsoft and happy with Apple
e.g.
"Notably, the speaker itself is anchored and vibration-proofed by way of some (very Apple-esque) rubber screw gaskets."
"A tall standoff spacer, reminiscent of those found in 27" iMacs, holds this beast in place."
"nasty Surface adhesive? Nice iMac adhesive?"
I get the last one, but the first two are very commonly used in the industry
Vince Longman -
As a reply to plink53, everything about this teardown is reparable with relatively inexpensive tools. Moreover, the things most people would want to replace, like the hard drive, are standard and replaceable without needing to remove the entire display.
I find the 5 repair score fair.
tm56 - Yanıt
So how difficult would it be to connect this monitor to a stand-alone PC tower?
Nelson Ocampo - Yanıt
Well considering that most video cards for desktop PCs only have DisplayPort, HDMI, or DVI outputs, it would be quite difficult. You would have find a way to convert the signal into a compatible signal for the display of the Surface. Then you would have to adapt your HDMI/DVI, or DisplayPort connection to the Surface's display ribbon cable. It would be quite a pain in the ass. Like trying to connect a laptop screen to a PC tower.
trythetrunk -
If one of these were purchased and the HD swapped with a faster/larger one, does anyone know of a way in which to get the OS, drivers, etc. to install and setup properly? All MS says is that doing so will void a warranty, and there's no mention of an OS, drivers, or otherwise being available.
Mav - Yanıt
I assume that you just download the recovery image for Surface Studio (like for all the other Surfaces) from Microsoft's website and put it on your flash drive.
https://www.microsoft.com/surface/en-us/...
The Raptor -
I don't understand why MS made the power supply internal. Takes about 1/4 of the precious space. BIG waste.
lauwarm - Yanıt
However the base needs to have a certain weight and size in order to make the unit relatively stable and not topple over anytime the neighbour opens the front door. So good thinking to put it in the base.
Ruurd Pels -
I doubt that the weight makes a lot for a stable stand. Balance between base and screen and the dimensions of the base are much more important.
lauwarm -
Can't make everyone happy. I see tons of people complaining about Xbox bricks.
brian -
Precious space for what? This isn't a tablet. You don't need the precious space for a larger battery or other sensors. Most people don't want a power brick on the outside. They want a simple, single power cord.
yury merrit -
Anyone else have any issue with the fan in the power supply making rattling noises? I ripped it out and ordered a replacement part. Seems to be running fine the last several days without it. That sound was super annoying.
photographer -
Boo, soldered ram. Puts on $5000 rose colored iSpectacles. I mean hooray, Microsoft is getting "courage" too!
michaeldthompson - Yanıt
I would love to get one of these for free. I would sell it and buy a car. :D
Yowza, that's a lot of copper! I like that in the Studio and Surface Book performance base, Microsoft is creating novel cooling setups to allow higher TDP parts in smaller spaces, rather than engineering ways to just get thinner for the same or lower TDPs. If you catch my drift on examples of the latter...
tipoo - Yanıt
64GB and 128GB SSDs for the hybrid storage - well that successfully avoids my most pessimistic view, I thought maybe they were talking about hybrid drives like the Momentus XT (though that was dispelled on their spec sheet soon after the presentation).
It also starts far higher than the 24GB that you'll get if you order a 1TB Fusion Drive in an iMac.
tipoo - Yanıt
?. My 5k got 128gb with fusion 1tb
Dmitrij Iermolaiev -
Great teardown, very entertaining. I'm still baffled why they aim this at a high end user and they don't offer a larger SSD size. I was scared it would be those horrible hybrid drives so at least it's not that!
Mark Cho - Yanıt
On the motherboard is the "Intel GL82CM236 Platform Hub Controller" which supports up to 8 SATA III (6.0 Gb/s) Ports.
A 2.5" SSD should be able to run at SATA III speed.
The Raptor - Yanıt
Very disappointing that the m.2 is sata rather than pcie x4. Huge difference in performance. IFixit: can you tell if the m.2 connector/hardware would support pcie? And if so, x2 or x4? Thanks
Charles Wallace - Yanıt
Related question - iFixit's teardown unit was the low-end model, with 64gb SATA M.2 module. I wonder if the larger M.2 (128gb?) in the high-end model uses PCIE? x2 or x4? Anyone know?
Charles Wallace -
@Charles Wallace @The Raptor
Yes, M.2 SATA and M.2. PCIe cards have different connectors, but many motherboard sockets can accept either. If you look closely at this image from Step 7 it appears the connector doesn't force the second key so a M.2 PCIe card would be able to fit: https://d3nevzfk7ii3be.cloudfront.net/ig...
The remaining question is then if the controller supports it.
Red -
@redflight
My mistake. I've check Kingston's website and it's possible systems have M.2 sockets that can support either SATA or PCIe.
https://www.kingston.com/us/ssd/system-b...
The real question is whether the controller supports PCIe protocol.
We might not know the answer until someone tries putting in a PCIe SSD.
The Raptor -
What is more important, is that it is only AHCI and not NVMe.
In particular, NVMe has much lower latency, and massively greater parallelisation which greatly increases performance for virtual memory.
Both this machine and the new MacBook Pro's have soldered memory but this will be far more limiting without NVMe support, which the MacBook Pro's have.
alex -
The answer is yes.
@theofficemaven confirms that the Surface Studio with Intel Core i7 comes with a 128GB Toshiba XG3 THNSN5128GPU7 M.2 2280 PCIe 3.0 x4 NVMe SSD installed.
The Raptor -
What kind of connector is the display hooked to the motherboard by? Wondering it it's possible to connect the display to another computer
Jimmy Misto - Yanıt
I have also been wondering about this... I looked at the zoomed in images in search of what type the connectors were but I have no idea. Any insight would be awesome!
Conrad Cunningham -
Is anyone else annoyed by the fact that they keep putting 5400 rpm hard drives in instead of 7200 rpm hard drives? I mean what is a few cents to throw in the faster drive?
gjcorlett - Yanıt
"The RAM, CPU, and GPU are soldered to the board and cannot be upgraded. "
Yes they can. But it is not worth doing it.
A SATA SSD instead of PCIe and a freaking HDD for how much they charge for this thing? That's absurd.
Michael Hoadley - Yanıt
The Surface Studio model with Intel Core i7 has PCIe SSD.
The Raptor -
Please tear down the mouse and the keyboard that came with it!
Michael Lombardi - Yanıt
Is the GPU soldered or not.
Nilam Patel. - Yanıt
Someone will make a fortune if they can figure out a way nto connect this beautiful screen to another PC. It would give the Surface Studio a 10 year life span because the only thing holding this equipment back, and as constantly stated in ALL reviews, is the antique hardware used in the base.
Any takers to come up with a way to achieve this?
Ian Baker - Yanıt
If some kind of adjustment would allow that by loosing on the vertical end.
Thanks in advance
elpachato - Yanıt
iFixit非常棒!!!!!!!!!!!!!!!!!!!!!!!!
钟致远电脑服务 - Yanıt
Is it possible to trash the bottom part and connect it to a very powerful gaming machine or workstation as a touch and pen enabled monitor?
gcelikkol - Yanıt
Is it possible to leave the bottom gutted and use something to make it just a display for a more powerful machine?
Christian Church - Yanıt
What’s a Macronix MX25L1006E 1 Mb CMOS serial flash? Does that replace the use of a CMOS battery?
Fernando Luís Paludo - Yanıt
A question, “Four SK Hynix H5GC4H24AJR 512 MB GDDR5 SDRAM “, are they been used as hard drive cache?
yang wang - Yanıt
This is Javed from India and I want to purchase SMPS of the same surface studio Part number -x937405-008 please help and share the quatation at javedaqeel76@gmail.com
Javed Aqeel - Yanıt
do you know where to buy a entire desplay assembly?
John Coffey - Yanıt
A high-quality wholesale VoIP termination service provider ensures all the calls are routed the right way in the event of errors and technical problems. Thus, businesses and public sectors rely entirely on this communication model as the revenues and profits earned suffer no damage.
<a href="https://technumus.com/advantages-of-sele...>ADVANTAGES OF SELECTING WHOLESALE VOIP TERMINATION</a>
Johan william - Yanıt
Sort of wish the pictures were better. Cannot read the numbers on the chips, so a little hard to reverse-engineer the design.
I know that wasn't the purpose but would have me, so I don't have to take mine apart [yet]
Eric Snyder - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 52
Son 30 gün: 381
Her zaman: 114,942
