Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Microsoft Wireless Mobile Mouse 1850 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Microsoft Wireless Mobile Mouse 1850 Teardown, Top case: adım 1, 1 resimden 1.
    • I unclipped the 9 clips holding the top case to the body.
  2. Microsoft Wireless Mobile Mouse 1850 Teardown: adım 2, 1 resimden 1.
    • I unscrewed the 3 Torx T6 Screws holding the body onto the bottom case
  3. Microsoft Wireless Mobile Mouse 1850 Teardown: adım 3, 1 resimden 1.
    • I undid the two Philips #00 screws on the motherboard
  4. Microsoft Wireless Mobile Mouse 1850 Teardown, Fully Disassembled: adım 4, 1 resimden 1.
    • That’s it!
Jed Calvert
293 İtibar
2 adet Kılavuz yazıldı
3 Yorum
Good work easy to understand instructions
jhoneycutt323 - Yanıt
My mouse had a battery leak inside of it. I removed the dud battery and tried to clean it a little but it would not work. After following these instructions I was able to fully disassemble the mouse and clean it out with soapy water, rinse in clean water, dry off with compressed air, and then clean in isopropyl alcohol and dry off with compressed air.
The mouse now works perfectly and doesn't need to go to the landfill.
Thank you very much!
Sam
Sam Stockwell - Yanıt
Well done on saving it instead of dumping it!
Glad I could help.
Jed Calvert -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 85
Her zaman: 3,924
