Ana içeriğe geç
Midiman Oxygen 8 Potentiometer Removal Teardown
Neye ihtiyacın var
  1. Midiman Oxygen 8   Potentiometer Removal Teardown, Midiman Oxygen 8 Backplate Disassembly: adım 1, 2 resimden 1. Midiman Oxygen 8   Potentiometer Removal Teardown, Midiman Oxygen 8 Backplate Disassembly: adım 1, 2 resimden 2.
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
  2. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 2, 2 resimden 1. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 2, 2 resimden 2.
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
  3. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 3, 3 resimden 1. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 3, 3 resimden 2. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 3, 3 resimden 3.
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
  4. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 4, 2 resimden 1. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 4, 2 resimden 2.
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
  5. Midiman Oxygen 8   Potentiometer Removal Teardown, Midiman Oxygen 8   Potentiometer Removal Teardown: adım 5, 1 resimden 1.
    • This is the location of the tuning potentiometer circuit retaining screws, 5 each 10mm long M3 galvanized Philips head machine screws
  6. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 6, 1 resimden 1.
    • Remove all five screw in any order with the J1 screwdriver head from the Ifixit tool kit.
  7. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 7, 1 resimden 1.
    • The black plastic knobs have no set screws and are removed by simply applying upward pressure.
    • Once all eight knobs are pulled off, use the open end of a 10mm wrench to loosen and remove the potentiometer retaining nuts on all eight knobs.
  8. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 8, 2 resimden 1. Midiman Oxygen 8   Potentiometer Removal Teardown: adım 8, 2 resimden 2.
    • Once the retaining nuts and screws are removed, the circuit board with the attached potentiometers will easily separate from the front plate.
    • To replace the damaged potentiometer, de-solder the three connections, replace with a new potentiometer, and re-solder the connections.
Sonuç
jad dalal
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 707
