Sökmek
Bu teardown bir tamir kılavuzu değildir. Morphy Richards Iron cihazınızı onarmak için, servis kılavuzumuzu kullanın.
This is the iron we will take apart.
First remove the rear or the iron using the flathead screwdriver.
Next remove the cable bridge bracket.
Next remove the screws from the base. (see arrows for location)
Next remove the screw the hold the top on.
To free the long cable remove from terminal block at rear.
At the front of the iron pull out the buttons for the steam and water.
Next unclip the button holder (red circle) by undoing the screws (black circle)
Next remove the bridge clip from the arrows position.
Next remove the inner button (black circle)
Now remove the centre screw (red arrow)
slide off the cable holder from the cable.
Disassemble the plug
First remove the casing.
Now remove the wires from the pins.
Next remove the pins.
Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
Next take out round selector, this is simply clipped so can be pulled out with pliers.
Next remove the washer parts at the front of the iron.
Take the tubing off.
Remove the seals for the water pump.
Now take pumps out.
Remove the screw (circled) this will lead to the separation of the base and the top.
Remove the top of the iron to reveal the under parts.
Now remove the rubber seals from the plate.
Take out the screws linking to the stainless steel base.
Remove the terminal block from the wires.
Next take off the black section of the iron.
Now remove the screws from the steel base.
Next remove each individual part ( mostly wiring)
All parts at the end of the process.
2 tane daha katılımcı ile
269 İtibar
1 Kılavuz yazıldı
Rozetler: 0
Bu kılavuzu, sitenizin / forumunuzun içine küçük bir parçacık olarak yerleştirmek için, bir boyut seçin ve aşağıdaki kodu kopyalayın.
Son 24 Saat: 8
Son 7 gün: 24
Son 30 gün: 151
Her zaman: 32,858
