Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Motorola C350 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Motorola C350 Teardown, Rear case freeing: adım 1, 2 resimden 1. Motorola C350 Teardown, Rear case freeing: adım 1, 2 resimden 2.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Teardown, Removing battery: adım 2, 1 resimden 1.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Teardown, Separating the front case: adım 3, 2 resimden 1. Motorola C350 Teardown, Separating the front case: adım 3, 2 resimden 2.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Teardown, Keyboard: adım 4, 1 resimden 1.
    • Use your thumb to gently peel the keyboard off the front case.
    • Be careful, the plastic on which the keyboard is stuck is pretty fragile.
  5. Motorola C350 Teardown, Logic Board: adım 5, 2 resimden 1. Motorola C350 Teardown, Logic Board: adım 5, 2 resimden 2.
    • Remove the 4 T6 Torx screws
  6. Motorola C350 Teardown: adım 6, 2 resimden 1. Motorola C350 Teardown: adım 6, 2 resimden 2.
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  7. Motorola C350 Teardown: adım 7, 1 resimden 1.
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  8. Motorola C350 Teardown, Ear Speaker: adım 8, 2 resimden 1. Motorola C350 Teardown, Ear Speaker: adım 8, 2 resimden 2.
    • Remove the four T6 Torx Screws
  9. Motorola C350 Teardown: adım 9, 1 resimden 1.
    • Use a metal spudger togently free the screen/ear speaker metal case.
  10. Motorola C350 Teardown: adım 10, 1 resimden 1.
    • Slowly peel the ear speaker off the case.
    • Be really careful about the small plastic pin which can be easily lost.
  11. Motorola C350 Teardown, Display: adım 11, 1 resimden 1.
    • Remove the two small metal clips keeping the cables safe.
  12. Motorola C350 Teardown: adım 12, 1 resimden 1.
    • Use a plastic spudger to pell off the two cables on the back side of the screen.
    • There are two very small connectors. Take care of them and replace them if they incidentally fall.
  13. Motorola C350 Teardown: adım 13, 1 resimden 1.
    • Use a plastic spudger to release the disconnected screen.
  14. Motorola C350 Teardown, Microphone: adım 14, 1 resimden 1.
    • Use a plastic spudger to unclip the mic.
  15. Motorola C350 Teardown, Upper Speaker: adım 15, 1 resimden 1.
    • The upper speaker is kept in place by a metal plate.
    • Use a metal spudger to free the 3 clips on the back side
  16. Motorola C350 Teardown: adım 16, 1 resimden 1.
    • Insert your metal spudger to remove the metal plate and free the upper speaker.
  17. Motorola C350 Teardown, Parts overview: adım 17, 1 resimden 1.
    • Here you can see all the parts composing the Motorola C350.
Vincent Monteil
6.975 İtibar
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 1,727
