Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Motorola California Mobile Phone cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Motorola California Mobile Phone Teardown, Motorola California Mobile Phone Teardown: adım 1, 1 resimden 1.
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Teardown: adım 2, 1 resimden 1.
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Teardown: adım 3, 1 resimden 1.
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Teardown: adım 4, 1 resimden 1.
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Teardown: adım 5, 1 resimden 1.
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Teardown: adım 6, 1 resimden 1.
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
Andrew Lam
35 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G46
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 7,583
