Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Motorola Moto G 2nd Generation cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Motorola Moto G 2nd Generation Teardown, Motorola Moto G 2nd Generation Teardown: adım 1, 2 resimden 1. Motorola Moto G 2nd Generation Teardown, Motorola Moto G 2nd Generation Teardown: adım 1, 2 resimden 2.
    • Remove back cover. It's easy, no adhesive and no screws.
  2. Motorola Moto G 2nd Generation Teardown: adım 2, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 2, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 2, 3 resimden 3.
    • Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
  3. Motorola Moto G 2nd Generation Teardown: adım 3, 2 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 3, 2 resimden 2.
    • Take away the volume button and power button.
  4. Motorola Moto G 2nd Generation Teardown: adım 4, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 4, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 4, 3 resimden 3.
    • Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
  5. Motorola Moto G 2nd Generation Teardown: adım 5, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 5, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 5, 3 resimden 3.
    • Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
  6. Motorola Moto G 2nd Generation Teardown: adım 6, 1 resimden 1.
    • At that time, remove the battery with SIM & SD card reader assembly together.
  7. Motorola Moto G 2nd Generation Teardown: adım 7, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 7, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 7, 3 resimden 3.
    • Separate battery and SIM & SD card reader assembly.
  8. Motorola Moto G 2nd Generation Teardown: adım 8, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 8, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 8, 3 resimden 3.
    • Release LCD screen connector from motherboard.
  9. Motorola Moto G 2nd Generation Teardown: adım 9, 2 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 9, 2 resimden 2.
    • Release sensor flex connector and front camera connector respectively.
  10. Motorola Moto G 2nd Generation Teardown: adım 10, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 10, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 10, 3 resimden 3.
    • Remove screws on the motherboard and the motherboard can be removed easily.
  11. Motorola Moto G 2nd Generation Teardown: adım 11, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 11, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 11, 3 resimden 3.
    • Remove rear camera.
  12. Motorola Moto G 2nd Generation Teardown: adım 12, 3 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 12, 3 resimden 2. Motorola Moto G 2nd Generation Teardown: adım 12, 3 resimden 3.
    • Remove front camera and sensor cable.
  13. Motorola Moto G 2nd Generation Teardown: adım 13, 2 resimden 1. Motorola Moto G 2nd Generation Teardown: adım 13, 2 resimden 2.
    • Remove earpiece and loudspeaker.
  14. Motorola Moto G 2nd Generation Teardown: adım 14, 1 resimden 1.
    • Done.
Sophia
43.783 İtibar
62 adet Kılavuz yazıldı
13 Yorum
Nice work!
REQUEST: Next time you do a cell phone would you also shoot a straight down on top shot. The 3/4 is nice but I want to look straight down !
TY
Top View - Yanıt
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
T-Mobile Huawei Prism U8651T Teardown
Top View -
Can anyone please tell me where I can get the details of the Antenna used for the GSM connection in this phone? Like the drawing or schematic.
Please I really need this as this phone has poor cell reception.
Amol - Yanıt
My Moto G just burned with 12 V from a cheap auto-recharger. But I lost very important data on the 8 GB memory. Is there a possible way to save the data?
mihaibanditu - Yanıt
Where can I get more information about GPS module and its antenna?
Paulo Abner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 53,603
