Ana içeriğe geç
Motorola Moto G3 Teardown
Neye ihtiyacın var
Videoya Genel Bakış
  1. Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: adım 1, 2 resimden 1. Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: adım 1, 2 resimden 2.
    • Remove back cover.
    • Moto G3 plastic panel can be easily removed with the fingernails.
  2. Motorola Moto G3 Teardown: adım 2, 2 resimden 1. Motorola Moto G3 Teardown: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
  3. Motorola Moto G3 Teardown: adım 3, 2 resimden 1. Motorola Moto G3 Teardown: adım 3, 2 resimden 2.
    • Undo 3 screws by T4 Torx screwdriver.
    • Take away plastic securing part.
  4. Motorola Moto G3 Teardown: adım 4, 3 resimden 1. Motorola Moto G3 Teardown: adım 4, 3 resimden 2. Motorola Moto G3 Teardown: adım 4, 3 resimden 3.
    • Heat up the LCD screen for a while.
    • Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives.
    • There is LCD screen connector on the left side, so be careful to slide guitar picks.
    start prying the screen off from the top corners very gently. I started from the bottom and shattered the glass
    Bob Mcroy - Yanıt
    A que temperatura debe estar el aire caliente? Durante cuánto tiempo?
    Luis - Yanıt
  5. Motorola Moto G3 Teardown: adım 5, 3 resimden 1. Motorola Moto G3 Teardown: adım 5, 3 resimden 2. Motorola Moto G3 Teardown: adım 5, 3 resimden 3.
    • Release LCD screen connector firstly.
    • Remove LCD screen.
  6. Motorola Moto G3 Teardown: adım 6, 3 resimden 1. Motorola Moto G3 Teardown: adım 6, 3 resimden 2. Motorola Moto G3 Teardown: adım 6, 3 resimden 3.
    • Undo 14 screws by T4 Torx screwdriver
    • Pry up motherboard assembly.
    • Battery flex connector is connected with motherboard, so be careful to pry the assembly up.
  7. Motorola Moto G3 Teardown: adım 7, 2 resimden 1. Motorola Moto G3 Teardown: adım 7, 2 resimden 2.
    • Release battery flex connector.
    • Separate motherboard assembly from back cover assembly.
  8. Motorola Moto G3 Teardown: adım 8, 3 resimden 1. Motorola Moto G3 Teardown: adım 8, 3 resimden 2. Motorola Moto G3 Teardown: adım 8, 3 resimden 3.
    • Undo 3 screws here.
    • Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
  9. Motorola Moto G3 Teardown: adım 9, 2 resimden 1. Motorola Moto G3 Teardown: adım 9, 2 resimden 2.
    • Remove front-facing camera.
  10. Motorola Moto G3 Teardown: adım 10, 3 resimden 1. Motorola Moto G3 Teardown: adım 10, 3 resimden 2. Motorola Moto G3 Teardown: adım 10, 3 resimden 3.
    • Remove rear camera.
  11. Motorola Moto G3 Teardown: adım 11, 2 resimden 1. Motorola Moto G3 Teardown: adım 11, 2 resimden 2.
    • Remove earpiece.
  12. Motorola Moto G3 Teardown: adım 12, 2 resimden 1. Motorola Moto G3 Teardown: adım 12, 2 resimden 2.
    • Remove loudspeaker.
  13. Motorola Moto G3 Teardown: adım 13, 2 resimden 1. Motorola Moto G3 Teardown: adım 13, 2 resimden 2.
    • Here is the motherboard.
  14. Motorola Moto G3 Teardown: adım 14, 2 resimden 1. Motorola Moto G3 Teardown: adım 14, 2 resimden 2.
    • Use spudger to cut adhesive and pry the battery up.
  15. Motorola Moto G3 Teardown: adım 15, 3 resimden 1. Motorola Moto G3 Teardown: adım 15, 3 resimden 2. Motorola Moto G3 Teardown: adım 15, 3 resimden 3.
    • Take away headphone jack.
  16. Motorola Moto G3 Teardown: adım 16, 1 resimden 1.
    • Done
Bitiş Çizgisi
20 farklı kişi bu kılavuzu tamamladı.
Witrigs
70.261 İtibar
377 adet Kılavuz yazıldı
7Kılavuz Yorumları
Muito bom, parabéns!
Manoel - Yanıt
Could you guys tell me if the main speaker, at the bottom, has a special protection agains water spills, like a membrane or so, or is it pretty fine too spill water there?
setsuoleandro - Yanıt
Wi fi not trun on ..moto g3
Seoni Seoni - Yanıt
When you heat up the display, do you heat up the entire display or just around the edges? What heat gun/setting should i use? Can i use a blowdryer?
guest - Yanıt
Thanks. ......................
Biswajit Saha - Yanıt
Anyone know where the GPS antenna is? I'm having issues with intermittent loss of GPS signal and would like to try re-seating or replacing the antenna.
saml604 - Yanıt
Excelente tutorial Gracias
Oscar Lopez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 53
Her zaman: 24,472
