Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Motorola Moto X 2nd Generation cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Motorola Moto X 2nd Generation Teardown, Motorola Moto X 2nd Generation Teardown: adım 1, 3 resimden 1. Motorola Moto X 2nd Generation Teardown, Motorola Moto X 2nd Generation Teardown: adım 1, 3 resimden 2. Motorola Moto X 2nd Generation Teardown, Motorola Moto X 2nd Generation Teardown: adım 1, 3 resimden 3.
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Teardown: adım 2, 3 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 2, 3 resimden 2. Motorola Moto X 2nd Generation Teardown: adım 2, 3 resimden 3.
    • Insert the eject pin into the hole inside of the port and push to open a gap between back cover and frame.
    • Place the guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Teardown: adım 3, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 3, 2 resimden 2.
    • Slide the guitar pick to cut the adhesive sticker under the cover. It's a little strong. Finally, peel off the soft back cover.
    To remove this cover easily, it is better to have a thermal blower on hand,to soften the glue.
    planob2 - Yanıt
  4. Motorola Moto X 2nd Generation Teardown: adım 4, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 4, 2 resimden 2.
    • Remove those two rubber cover.
  5. Motorola Moto X 2nd Generation Teardown: adım 5, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 5, 2 resimden 2.
    • Release the side button flex connector and battery connector respectively under the rubber cover.
  6. Motorola Moto X 2nd Generation Teardown: adım 6, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 6, 2 resimden 2.
    • Twist off all 18 screws on the middle housing and remove it easily.
  7. Motorola Moto X 2nd Generation Teardown: adım 7, 3 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 7, 3 resimden 2. Motorola Moto X 2nd Generation Teardown: adım 7, 3 resimden 3.
    • Remove the logo.
  8. Motorola Moto X 2nd Generation Teardown: adım 8, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 8, 2 resimden 2.
    • Get the flex loosen from battery
  9. Motorola Moto X 2nd Generation Teardown: adım 9, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 9, 2 resimden 2.
    • Get the flex loosen from the battery.
  10. Motorola Moto X 2nd Generation Teardown: adım 10, 3 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 10, 3 resimden 2. Motorola Moto X 2nd Generation Teardown: adım 10, 3 resimden 3.
    • Pull the battery sticker and pry up the battery.
  11. Motorola Moto X 2nd Generation Teardown: adım 11, 3 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 11, 3 resimden 2. Motorola Moto X 2nd Generation Teardown: adım 11, 3 resimden 3.
    • Twist off the screw and pry up the securing bracket.
  12. Motorola Moto X 2nd Generation Teardown: adım 12, 1 resimden 1.
    • Remove the side buttons flex.
  13. Motorola Moto X 2nd Generation Teardown: adım 13, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 13, 2 resimden 2.
    • Release LCD connector.
  14. Motorola Moto X 2nd Generation Teardown: adım 14, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 14, 2 resimden 2.
    • Release digitizer connector.
  15. Motorola Moto X 2nd Generation Teardown: adım 15, 3 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 15, 3 resimden 2. Motorola Moto X 2nd Generation Teardown: adım 15, 3 resimden 3.
    • Pry up the motherboard and remove it carefully. At that time, we can separate the LCD screen from motherboard and get it alone.
  16. Motorola Moto X 2nd Generation Teardown: adım 16, 3 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 16, 3 resimden 2. Motorola Moto X 2nd Generation Teardown: adım 16, 3 resimden 3.
    • Release the connector and remove the rear camera.
  17. Motorola Moto X 2nd Generation Teardown: adım 17, 2 resimden 1. Motorola Moto X 2nd Generation Teardown: adım 17, 2 resimden 2.
    • Remove front camera.
  18. Motorola Moto X 2nd Generation Teardown: adım 18, 1 resimden 1.
    • Done.
Sophia
43.810 İtibar
62 adet Kılavuz yazıldı
8 Yorum
Poking out the back cover through the SIM slot does NOT work on the leather backed version. I almost poked a hole through the leather but thankfully it held together. Maybe applying a heat gun to soften the glue would make this work.
tharty416 - Yanıt
When I reassembled my Moto X 2nd gen. after a battery change, I lost audio to the speaker. Audio jack works fine. Nothing is torn, but definitely something loose or not connected. I don't know where to look. Could you please help guide me to where it might be? Thanks!
phamtoan - Yanıt
I have a solution to the speaker not working after putting the phone back together.
The speaker wasn't connecting with the metal tabs on the phone back panel due to my replacement battery being a little thicker.
I was able to bend the speaker contact pins to connects with the relevant connectors and it started working. Slightly hacky but worked. I have posted pictures https://plus.google.com/+BenSycha/posts/...
Ben Sycha -
@wasrel Where did you purchase a replaccement battery and was it new?
Doug Hellinger -
Same problem. What is the answer?
alekskoptev - Yanıt
I found a solution, look at my reply to phamtoan.
Ben Sycha -
thanks. it works again. made it with a little piece of metal film
alekskoptev -
What is the screw type (the thread size and length) for the screws that hold the phone together? I somehow messed up the screw heads beyond repair, even though I had a correct screw driver :(
Lena Zhivun - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 37,616
