Giriş
Wanna know how to disassemble Motorola Moto X Force? Here show detailed steps.
Neye ihtiyacın var
Use heat gun to heat up back cover firstly.
Insert metal opening tool to open a gap and cut adhesives around.
Twist off 17 screws by T3 Torx screwdriver.
Take away rubber bracket securing NFC antenna and release NFC antenna connector.
After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
Release MIC connector.
There are adhesives existed underneath.
There are a little bit adhesives around, but you can peel this part easily.
Peel off the tape.
Twist off 2 screws.
The motherboard bracket is electrically connected to the motherboard by a very delicate spring connector. Any lateral force on the connector will snap it off the motherboard. Take care not to apply any lateral force to the connector when removing the motherboard bracket. Any damage to the connector could result in it breaking off at a later date and causing short circuits in other components within the phone. The connector is to the right of the side button connector and above the copper film covered component.
Release this two connectors carefully.
The LCD assembly has two connectors, here is touchscreen connector.
Release signal cable connector.
Pry the motherboard assembly up.
Use tweezers to release the connector.
With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
Be careful to pry this part up, because it tends to fall apart easily.
9 Yorum
>>Here is LCD screen with LCD supporting frame.
amoled
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
can i use droit turbo 2 logic board on moto x force? i whant to change logic board becous my is crashed
:) Several very odd responses to this teardown, so I'll be the first to say.....
Thanks very very much Eric and other contributers, for taking the time to leave this guide. It's perfect and helped me get the thing apart without killing it - aint they a pain when they keep turning back on? I just want to mention thsi one extra bit.....
Be careful when prizing the back off the phone, it stuck so well on the one I've just done (even though I've fixed dozens of phones and am very familiar with the 'heating up' process to soften the glue, well in fidlling about with it, I was horrified to see I'd pressed the buttons in just the right way to get it to boot into its RECOVERY menu, and one more button press would have erased the customers contents!! *gulps*.
This happened despite the fact that the phones battery has been so flat it could never turn on beyond showing the Flat Battery logo - still had enough power to get into Recovery LoL.
Many thanks again Eric :-)
Hi, i bouth a Motorola x force, and i have a problem with the dual sim, the sim 2 does not work as a sim, but work when i use with a memory card.- Thank you!!
