Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Motorola V3i cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Motorola V3i Teardown, Motorola V3i Teardown: adım 1, 1 resimden 1.
    • A Motorola V3i!
    • Let's see what's inside...
  2. Motorola V3i Teardown: adım 2, 2 resimden 1. Motorola V3i Teardown: adım 2, 2 resimden 2.
    • Let's turn it and take out the battery.
    • Remove these two screws.
  3. Motorola V3i Teardown: adım 3, 1 resimden 1.
    • Now you can easily flip the cover.
  4. Motorola V3i Teardown: adım 4, 3 resimden 1. Motorola V3i Teardown: adım 4, 3 resimden 2. Motorola V3i Teardown: adım 4, 3 resimden 3.
    • You need to detach these two plastic lashes from the surounding.
    • Now you can remove this transparent plastic case.
    • Now you can take out the speaker.
    • The metal thing on the end of the picture is the antenna.
  5. Motorola V3i Teardown: adım 5, 2 resimden 1. Motorola V3i Teardown: adım 5, 2 resimden 2.
    • So, that's the board.
    • Vibra motor.
    • Mini USB.
    • Connector for the antenna.
    • After I took these EMI shields away it looks like this...
  6. Motorola V3i Teardown: adım 6, 2 resimden 1. Motorola V3i Teardown: adım 6, 2 resimden 2.
    • Bluetooth chip by Broadcom.
    • 32Mbit PSRAM by STMicroelectronics.
    • Baseband Processor (Main Processor) by Freescale (90nm structure).
    • RF Transmitter by RF Micro Devices.
    • Battery controller by Freescale.
    • Quad-Band Transmit Module by RF Micro Devices.
  7. Motorola V3i Teardown: adım 7, 2 resimden 1. Motorola V3i Teardown: adım 7, 2 resimden 2.
    • Remove these 4 rubbers.
    • Then remove the four torx screws.
    • You can easily lose these rubbers. (That's why I have only 3 of them...)
  8. Motorola V3i Teardown: adım 8, 2 resimden 1. Motorola V3i Teardown: adım 8, 2 resimden 2.
    • Filp the device and you can remove the top housing.
    • Remove the three buttons on the side of the device.
    • Remove the connector to the mainboard...
    • and to the camera.
  9. Motorola V3i Teardown: adım 9, 1 resimden 1.
    • Remove the camera by lifting it up.
    • That's a 1,3Mpix camera!
  10. Motorola V3i Teardown: adım 10, 3 resimden 1. Motorola V3i Teardown: adım 10, 3 resimden 2. Motorola V3i Teardown: adım 10, 3 resimden 3.
    • Lift up the speaker.
    • Then, that's a tricky part,remove all the buttons around the screen housing. Caution: They are really thin and they easily break!
    • After you did this tricky part you can lift the top of the phone away.
  11. Motorola V3i Teardown: adım 11, 2 resimden 1. Motorola V3i Teardown: adım 11, 2 resimden 2.
    • Now lift up the front glass from the top of the device. It's held with adhesives.
    • After you did this it should look like this.
  12. Motorola V3i Teardown: adım 12, 2 resimden 1. Motorola V3i Teardown: adım 12, 2 resimden 2.
    • Around the screen there are some lashes. Detach them to release the screen of the metal housing.
    • Then you can lift the metal housing up.
  13. Motorola V3i Teardown: adım 13, 2 resimden 1. Motorola V3i Teardown: adım 13, 2 resimden 2.
    • The metal housing is very fragile!
    • an ATI Imageon chip! It's a mulitmedia co-processor, it is used for record video and mobile gaming. It support up to a 2Mpix camera.
  14. Motorola V3i Teardown: adım 14, 2 resimden 1. Motorola V3i Teardown: adım 14, 2 resimden 2.
    • Again there's a small lash on the botton of the front screen housing.
    • After that you can remove the front screen with the PCB.
  15. Motorola V3i Teardown: adım 15, 1 resimden 1.
    • The front screen.
    • Yes, my front screen has some dead pixels. (They are pink?!)
  16. Motorola V3i Teardown: adım 16, 1 resimden 1.
    • Thank you for reading my Teardown:)
Peddy
159 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Have an old V3i and the screen has just stopped working - have a feeling it’s become disconnected, is it work tearing it down like this to try fix the problem? Want it still to work after though
Iala - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 24,627
