Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. NBC Kentucky Derby Brooch cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. NBC Kentucky Derby  Brooch Teardown, Assemble Horse: adım 1, 3 resimden 1. NBC Kentucky Derby  Brooch Teardown, Assemble Horse: adım 1, 3 resimden 2. NBC Kentucky Derby  Brooch Teardown, Assemble Horse: adım 1, 3 resimden 3.
    • Gather all components and flip everything over.
    • Mount the head, tail, and both legs by placing them over their pivot points.
  2. NBC Kentucky Derby  Brooch Teardown, Attach linkage: adım 2, 3 resimden 1. NBC Kentucky Derby  Brooch Teardown, Attach linkage: adım 2, 3 resimden 2. NBC Kentucky Derby  Brooch Teardown, Attach linkage: adım 2, 3 resimden 3.
    • Carefully align the linkage with the mounting holes on both legs.
    • Place two 3mm eyeglass screws into either end of the linkage.
    • Tighten the screws. These screws will self-tap into the legs. Be careful to not over-tighten and seize the linkage.
  3. NBC Kentucky Derby  Brooch Teardown, Mount servo: adım 3, 3 resimden 1. NBC Kentucky Derby  Brooch Teardown, Mount servo: adım 3, 3 resimden 2. NBC Kentucky Derby  Brooch Teardown, Mount servo: adım 3, 3 resimden 3.
    • Pull the servo through the donut hole of the PCB (top to bottom).
    • Orient the servo arm to the left (aligned with the rest of the body). This represents the zero degree location.
    • Manually move the servo arm down 90 degrees so it is now points downward into the work surface.
    • Mount the servo to the enclosure.
  4. NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: adım 4, 3 resimden 1. NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: adım 4, 3 resimden 2. NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: adım 4, 3 resimden 3.
    • Place the PCB overtop the servo.
    • Route the servo's wire around various components as depicted.
    • Coil extra wire in available space.
  5. NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: adım 5, 3 resimden 1. NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: adım 5, 3 resimden 2. NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: adım 5, 3 resimden 3.
    • Align the enclosure with the mounting holes on the backside of the horse's body.
    • Align servo arm with the drive gap in the linkage. Double check this correct before tightening.
    • Use two M2 screws to attach the horse to the enclosure.
  6. NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: adım 6, 3 resimden 1. NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: adım 6, 3 resimden 2. NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: adım 6, 3 resimden 3.
    • Start by placing the bottom notched-side into the lip of the enclosure.
    • Align all three mounting holes from above.
    • Press firmly with both hands (avoid putting pressure on horse) and work your hands around the edges until the back is pressed flush.
    • Secure the back of the enclosure by driving three M2 screws into place. DO NOT OVER TIGHTEN!
  7. NBC Kentucky Derby  Brooch Teardown, Give it power: adım 7, 2 resimden 1. NBC Kentucky Derby  Brooch Teardown, Give it power: adım 7, 2 resimden 2.
    • Attach wiring harness to brooch.
    • Plug wiring harness into USB power supply.
Justin Sinichko
165 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 970
