Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. NeXTstation cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. NeXTstation Teardown, NeXTstation Teardown: adım 1, 3 resimden 1. NeXTstation Teardown, NeXTstation Teardown: adım 1, 3 resimden 2. NeXTstation Teardown, NeXTstation Teardown: adım 1, 3 resimden 3.
    • The NeXTStation, this is a great addition to any computer collection.
  2. NeXTstation Teardown: adım 2, 3 resimden 1. NeXTstation Teardown: adım 2, 3 resimden 2. NeXTstation Teardown: adım 2, 3 resimden 3.
    • Turn the NeXTStation around, and remove this screw:
    • Then, lift the top cover of the computer. This will reveal the guts.
    • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
    • I find notes in everything!
    " Keyboard & Mouse"
    Nope! Those are serial ports. The keyboard plugs into the monitor, and the mouse plugs into the keyboard.
    Also the DB-9 is the printer port, by which the NeXT laser printer was attached. I don't think it could be used for general serial communications. On the other hand, if I recall correctly the DSP port *was* usable for high-speed serial communications.
    jonhendry - Yanıt
  3. NeXTstation Teardown: adım 3, 2 resimden 1. NeXTstation Teardown: adım 3, 2 resimden 2.
    • Removing the hard drive:
    • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
    • Remove all of the cables from the logic board.
    It's incredible how modern this board looks, despite its being so dated.
    tabormeister - Yanıt
    tabormeister kullanıcısından alıntı:
    Yep, this was one fast of a workstation back in 90"
    Chris Green - Yanıt
  4. NeXTstation Teardown: adım 4, 3 resimden 1. NeXTstation Teardown: adım 4, 3 resimden 2. NeXTstation Teardown: adım 4, 3 resimden 3.
    • Then remove this screw.
    • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
    Wow, it is so easy to take everything out!!! Now there are milions of screws and connectors, turning devices around and so on... I'm amazed of the simplicity!
    jakub004 - Yanıt
  5. NeXTstation Teardown: adım 5, 1 resimden 1.
    • The Hard Drive & Caddy
  6. NeXTstation Teardown: adım 6, 3 resimden 1. NeXTstation Teardown: adım 6, 3 resimden 2. NeXTstation Teardown: adım 6, 3 resimden 3.
    • Removing the floppy disk drive:
    • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
    • Remove the floppy cable.
    • Then, remove this screw.
  7. NeXTstation Teardown: adım 7, 3 resimden 1. NeXTstation Teardown: adım 7, 3 resimden 2. NeXTstation Teardown: adım 7, 3 resimden 3.
    • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
  8. NeXTstation Teardown: adım 8, 3 resimden 1. NeXTstation Teardown: adım 8, 3 resimden 2. NeXTstation Teardown: adım 8, 3 resimden 3.
    • Removing the fan:
    • Remove this connector.
    • Remove these screws.
    • Remove the fan.
  9. NeXTstation Teardown: adım 9, 3 resimden 1. NeXTstation Teardown: adım 9, 3 resimden 2. NeXTstation Teardown: adım 9, 3 resimden 3.
    • Removing the logic board:
    • Remove the power supply connector. Just lift it straight up, and it should come free.
    • Remove this screw.
  10. NeXTstation Teardown: adım 10, 3 resimden 1. NeXTstation Teardown: adım 10, 3 resimden 2. NeXTstation Teardown: adım 10, 3 resimden 3.
    • Lift the end of the logic board(away from the ports), and slide it away from the ports.
    • Now, set the board aside.
  11. NeXTstation Teardown: adım 11, 3 resimden 1. NeXTstation Teardown: adım 11, 3 resimden 2. NeXTstation Teardown: adım 11, 3 resimden 3.
    • Power Supply:
    • Lift the power supply up, and out.
    The power supply is the (only?) weak spot on this beauty! It is always the MOSFETs which burn out. So make sure you use heat sink compound when you re-assemble it!
    If it is broken, maybe this page can help: http://heller.no-ip.org/~heller/NeXT/pow...
    Helmut Heller - Yanıt
  12. NeXTstation Teardown: adım 12, 1 resimden 1.
    • The Logic Board Overview:
    • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
    • The CPU: Motorola XC68040RC25
    • The Co-Procesor: MB610313
    • Motorola Chips
    • Intel Chips
    • AMD Chips (Intel and AMD In the same computer?)
    • Fujitsu Chips
    I think the MB610313 is a DMA controller ASIC.
    jonhendry - Yanıt
  13. NeXTstation Teardown: adım 13, 3 resimden 1. NeXTstation Teardown: adım 13, 3 resimden 2. NeXTstation Teardown: adım 13, 3 resimden 3.
    • Made in the USA, you don't see this anymore.
    • The Serial #
    • Looks like my NeXTStation came from WilTel.
    • It is model # N1100
Chris Green
36.978 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
3 Yorum
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Juddy - Yanıt
Juddy kullanıcısından alıntı:
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
Chris Green - Yanıt
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
HotelCoralEssex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 74
Her zaman: 30,837
