Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Nerf N-Strike Maverick cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Nerf N-Strike Maverick Teardown, Nerf N-Strike Maverick Teardown: adım 1, 1 resimden 1.
    • The Redeemer. Looks badass with its rotating barrel, but it's going to get a whole lot more badasserer quite soon...
    • Reminds me of a gun from the Fifth Element.
  2. Nerf N-Strike Maverick Teardown: adım 2, 1 resimden 1.
    • First thing's first: let's remove some screws. All screws are conveniently Phillips, and all can be removed with a #0 or #00 size screwdriver.
    • Remove all ten Phillips screws.
  3. Nerf N-Strike Maverick Teardown: adım 3, 3 resimden 1. Nerf N-Strike Maverick Teardown: adım 3, 3 resimden 2. Nerf N-Strike Maverick Teardown: adım 3, 3 resimden 3.
    • Another Phillips screw hides beneath the cocking mechanism thing. Remove that one as well.
    • The cocking mechanism's quite simple. A metal lever pulls back on the air plunger and compresses the large spring. Another small spring returns the slider back into its original position once it's done doing the dirty business..
  4. Nerf N-Strike Maverick Teardown: adım 4, 2 resimden 1. Nerf N-Strike Maverick Teardown: adım 4, 2 resimden 2.
    • And just like that, the gun comes apart.
    • Visible in the top left corner is the large spring and air plunger.
    • I later opened the gun again and put a folded piece of paper in this area. It gave the gun a bit more "punch" when sending darts on their merry way.
  5. Nerf N-Strike Maverick Teardown: adım 5, 1 resimden 1.
    • Gun tip. I foresee it being black in the future.
  6. Nerf N-Strike Maverick Teardown: adım 6, 2 resimden 1. Nerf N-Strike Maverick Teardown: adım 6, 2 resimden 2.
    • First comes out the air plunger. It lifts right up.
    • The barrel comes out next.
  7. Nerf N-Strike Maverick Teardown: adım 7, 2 resimden 1. Nerf N-Strike Maverick Teardown: adım 7, 2 resimden 2.
    • The trigger is held in place by a sole Phillips screw. It also has a small spring for that authentic handgun "springy" feeling...
  8. Nerf N-Strike Maverick Teardown: adım 8, 3 resimden 1. Nerf N-Strike Maverick Teardown: adım 8, 3 resimden 2. Nerf N-Strike Maverick Teardown: adım 8, 3 resimden 3.
    • The trigger's spring also attaches via a Phillips screw. A couple of twists with the screwdriver and it comes right out.
    • The fancy rotator for the barrel is next. I assume that were the gun to break, this would be the part that fails. It's the most complex part of the gun.
  9. Nerf N-Strike Maverick Teardown: adım 9, 1 resimden 1.
    • Looking down the gun's business end.
    • I didn't bother to take the barrel apart. I didn't feel that adventurous.
  10. Nerf N-Strike Maverick Teardown: adım 10, 1 resimden 1.
    • Here it is -- the whole gun taken apart.
    • It's so easy to assemble, a child could do it. Maybe Nerf's motto is "From our kids to your kids"?
    • I sincerely hope Nerf products are manufactured in countries that have strict child labor laws. I in no way, shape, or form condone child labor.
  11. Nerf N-Strike Maverick Teardown: adım 11, 2 resimden 1. Nerf N-Strike Maverick Teardown: adım 11, 2 resimden 2.
    • The finished product.
    • I took the gun to work and shot these pictures under a better lighting/camera setup... A much better lighting/camera setup.
4 Yorum
%#*@! Some kid stuck a marble down the barrel and I can't get it out. I have taken it apart to the same extent you did but can't get the barrel front or back removed. Any thoughts?
William - Yanıt
Set the barrel up so it’ll shoot where it’s not obstructed and shoot the kid until he buys you a new gun.
koannweinstein -
@sicra the gun has air restrictors that won’t shoot anything out unless a dart is pushing against it…
so the marble won’t come out by it’s own.
@William take the barrel apart it’s just 3 screws, and then you can remove it.
Phuwanut Pataratawinun - Yanıt
use a smallish dia. piece of tubing ( i used outer insulation of coax tv cable) and superrglue ( gel) to said marble let it getgooos and set, like an hour and gentlly pull it out
Valden Tharbosen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 83
Her zaman: 85,764
