Giriş
It got too dangerous. Shots were fired. Eyes were almost lost. It was time to downgrade.
One of our iFixit programmers was notorious for using his Nerf WMD randomly on co-workers, with no forewarning nor regard for their safety. On one of these occasions, said co-worker shot me in the eye with one of the darts. Thankfully I was wearing my glasses, and a full-on beatdown was avoided.
In retaliation I brought my never-used soft air handgun from home. We had a couple of laughs, a couple of stings, but it was largely fine up until one day, when I was aiming for the co-worker's arm and shot him in the neck instead.
I was quite disappointed by the lack of accuracy, and thought it hypocritical of me to compromise others' safety, when my own was so crucial to me. So I authorized a purchase of up to TEN DOLLARS with The Wife, and set out to find the best Nerf gun available.
This is it: The Nerf N-Strike Maverick.
Needless to say, the gun looks goofy and child-like in its original paint scheme. We all know that yellow is the color of cowards, so I decided to paint my new office weapon. I was also curious as to what was inside, and lazy (I wanted to paint both sides at the same time), so I torn'd this sucker down and took some pictures!
Enjoy!
Neye ihtiyacın var
The Redeemer. Looks badass with its rotating barrel, but it's going to get a whole lot more badasserer quite soon...
Reminds me of a gun from the Fifth Element.
First thing's first: let's remove some screws. All screws are conveniently Phillips, and all can be removed with a #0 or #00 size screwdriver.
Remove all ten Phillips screws.
I see from the final photos that of the 10 black Phillips screws, 2 are shorter?
I think one of the short ones is for the rearmost hole of the cocking slide, but any ideas where the other goes?
Actually there should be a total of 11 screws if we include the one hidden by the slide.
Found this other site. In the tear down it says there are three screws on the slide that are different than the others so I assume they are the short ones.
Another Phillips screw hides beneath the cocking mechanism thing. Remove that one as well.
The cocking mechanism's quite simple. A metal lever pulls back on the air plunger and compresses the large spring. Another small spring returns the slider back into its original position once it's done doing the dirty business..
Looking down the gun's business end.
I didn't bother to take the barrel apart. I didn't feel that adventurous.
The finished product.
I took the gun to work and shot these pictures under a better lighting/camera setup... A much better lighting/camera setup.
I am very afraid.
David Patierno kullanıcısından alıntı:
I am very afraid.
taking apart the barrel is where the fun starts. pry off the orange cylinder on either end, remove 3 screws from the black side of the barrel and it's open. take out the 6 springs and the short plastic pieces. set aside. take the long plastic pieces and trim the stems flush with the convex surface. take the springs, short plastic pieces, and the stems and throw them at somebody. put it all back together making sure the former stemmed pieces are tight and you now have the most awesome nerf gun ever!
check youtube, couple of videos there...
cheers!
4 Yorum
%#*@! Some kid stuck a marble down the barrel and I can't get it out. I have taken it apart to the same extent you did but can't get the barrel front or back removed. Any thoughts?
Set the barrel up so it’ll shoot where it’s not obstructed and shoot the kid until he buys you a new gun.
@sicra the gun has air restrictors that won’t shoot anything out unless a dart is pushing against it…
so the marble won’t come out by it’s own.
@William take the barrel apart it’s just 3 screws, and then you can remove it.
use a smallish dia. piece of tubing ( i used outer insulation of coax tv cable) and superrglue ( gel) to said marble let it getgooos and set, like an hour and gentlly pull it out
